Speed Density startup help
Old Feb 7, 2015 | 09:03 AM
RedNBlck's Avatar
Just put an evo 8 ECU in my evo 4. The car has been converted to sd. So i flashed the car with tephra v7 and the car doesn't start. It'll crank and try to start but it won't actually fire. I was wondering what are all the table that need to be touched when converting to sd in order for the car to start and drive. Thank yall for your time.
Old Feb 7, 2015 | 12:21 PM
Evilution226's Avatar
Just make sure everything is reconnected in the engine bay. Wires tight in connectors and splices are clean end tight. I will check mine for you.
Old Feb 7, 2015 | 07:24 PM
1fast97gsx's Avatar
Did you turn off the immobilizer?
Old Feb 8, 2015 | 12:24 AM
jeffbeagley's Avatar
Either immobilizer or Crank Sensor.
Old Feb 8, 2015 | 09:51 AM
RedNBlck's Avatar
I can post the bin when I get home if that helps.
Old Feb 8, 2015 | 01:31 PM
RedNBlck's Avatar
Here is the hex file I flashed the car with. ROM ID 94170015
File Type: hex
Old Feb 9, 2015 | 01:44 PM
todd6027's Avatar
thats not an sd rom you need 94171715 second post here
http://api.viglink.com/api/click?for...hramod-v7.html
then you need to disable the immobiliser in faa bits then change immo hex to 0040
mr 2.3 evo
11
Feb 26, 2010 01:04 PM
Dragking2189
Aug 31, 2009 10:18 PM
Dragking2189
Aug 31, 2009 09:50 PM
KillaItalian904
Aug 31, 2009 05:27 PM
sekula
Aug 25, 2009 12:51 PM
