speed density help!
Old Feb 8, 2010 | 08:14 PM
mr 2.3 evo's Avatar
speed density help!
recently ordered a speed density conversion and looking to install and wire it up. has anyone done this and have directions for wiring up the air intake temp sensor to the ecu?? any help would be great and tips for the install as well
Old Feb 8, 2010 | 08:16 PM
scheides's Avatar
EvoM Moderator
how do you 'order a speed density conversion' ?
Start here:
https://www.evolutionm.net/forums/ec...ched-roms.html
Then here:
https://www.evolutionm.net/forums/ec...?highlight=IAT
Old Feb 8, 2010 | 08:23 PM
mr 2.3 evo's Avatar
AWD Motorsports Stock ECU Speed Density Package!!
Our package will include...
Omni 4 Bar MAP Sensor
AIT Sensor w/ Pigtail
Choice of Aluminum or Steel Bung
Price: 160.00 Shipped
thats how you order a conversion
Old Feb 8, 2010 | 08:45 PM
Mike.p's Avatar
question abou t installing the iat.. can you just splice into the fuel temp wire instead of running it all the way to the ecu?
Old Feb 9, 2010 | 07:17 AM
scheides's Avatar
EvoM Moderator
Oh, I didn't know such a thing existed...I just had bought 'all' the parts individually and did a 'DIY' kit LOL. There is a wealth of info in the EcuFlash section, the links I provided should get you started.
If you know where the wire is, sure...otherwise just run it back to the ECU, pretty easy.
Old Feb 26, 2010 | 12:32 PM
ravnos04's Avatar
Is there a picture available to show me where this wire is? I searched through the forums and found nothing.
Old Feb 26, 2010 | 12:37 PM
scheides's Avatar
EvoM Moderator
http://www.roadraceengineering.com/e...-ecuwiring.htm
Pin #77, IIRC.
Old Feb 26, 2010 | 12:54 PM
JohnBradley's Avatar
IAT isnt even needed to be honest.
Old Feb 26, 2010 | 12:56 PM
ravnos04's Avatar
Really? My tuner and I tried without the sensor and just the Omni4 and my car wouldn't take the ROM. Wouldn't start at all. Any idea why?
Old Feb 26, 2010 | 12:57 PM
ravnos04's Avatar
Originally Posted by scheides
Thanks a lot, that helps.
Old Feb 26, 2010 | 01:01 PM
l2r99gst's Avatar
It should definitely start and run. I just helped someone tune their SD without their IAT sensor hooked up yet.
But, I would advise against it. If you don't have any temp comp, then your tune is going to be off the further you stray from the temp that you tune at.
Old Feb 26, 2010 | 01:04 PM
ravnos04's Avatar
Any idea why the car wouldn't start?
raulbz777
14
Jan 27, 2017 05:02 AM
need_an_evo
Mar 29, 2016 09:14 AM
need_an_evo
Mar 28, 2016 02:21 PM
QuickEvo
AEM EMS
19
Nov 16, 2005 09:21 AM
kcevo
AEM EMS
20
Sep 11, 2005 12:10 PM
