Go 2.2 or 2.3?
Old Feb 10, 2010 | 07:37 AM
Pow82's Avatar
Go 2.2 or 2.3?
Hi to all,
I am new to this forum n pls pardon me if there is a thread on this b4. I am just confuse if I should stroke to 2.2l or 2.3l. I am looking at street n circuit setup with BBk full. Pls advise. Thanks
p.s: I am currently on 2.4l ATP GT35R n find it lag n a torture to drive on street n circuit. So looking for instant spool n TQ setup.
Old Feb 10, 2010 | 01:05 PM
heel2toe's Avatar
Why not keep the 2.4 and just swap the turbo? The BBK will be so much more responsive than a 35r
Old Feb 10, 2010 | 01:09 PM
2003lancerevo8's Avatar
confused.... you should just keep the 2.4 and swap the setup.... if you really wanted to, stroke to a 2.3 but doesn't the 2.4 and the 2.3 use a different block...
I would keep the 2.4 and use the bbk...
you may wanna look at your engine setup and see what cams and such you have in there to see if you couldn't make any adjustments in that category as well.
Also,
do you have a sheet metal intake manifold? If so, ditch that and go to a ported stock manifold...
you will gain some spool back there
Good luck...
Old Feb 10, 2010 | 01:15 PM
LT1runner's Avatar
How can a 35R be laggy on a 2.4 ltr? When my motor was 2.3 on a 35R, it was great. Even with a bad tune my 2.2 is awesome with my T4Z88HTA.
Old Feb 10, 2010 | 01:17 PM
AWD Motorsports's Avatar
The lag is from the ATP kit not the motor.. If you think going to a 2.2 is going make it less laggy your not going to be happy.. Your turbo kit is whats laggy..
Mike
Old Feb 10, 2010 | 02:24 PM
boostin350z's Avatar
more displacement = less lag
swap your turbo
Old Feb 10, 2010 | 02:31 PM
Yeah, I am a moron, I didn't even see the ATP kit, they are always known to be a bit laggier than most.
Switch to the bbk with a stock ported intake manifold and a ported manifold you should be good to go....
Old Feb 10, 2010 | 08:14 PM
Pow82's Avatar
Thanks for all the comments and advises. My ATP turbo full boost at 5500RMP n my tuner says my 2.4l can't rev high which cuts at 7500RPM. I really miss the torque response of my Evo. Btw I am on GSC S2 n Kansai Intake Manifold.
My fren selling me his 2.2l stroker kit at a v.gd price tat I don't mind considering getting rid of my 2.4l n get his.
Anyone of you guys here had a setup like 2.2l with small turbo e.g 20G or BBK? Would like to hear from you.
Old Feb 10, 2010 | 08:46 PM
sparky's Avatar
If you go over to the Evo Dyno Tuning and Results sub-forum there is a current thread by Mike at AWD that features a 550WHP/550WTQ 2.4L. Evo with a BBK turbo.
Old Feb 12, 2010 | 05:55 AM
ranz's Avatar
keep the 2.4,swap the turbo to bbk and do some porting.
Old Feb 26, 2010 | 01:57 AM
Pow82's Avatar
Now I am deciding to use between BBK full or HKS 3037 for my 2.2l stroker. Can anyone pls advise?
Not forgetting I am looking for street (Daily Drive) n circuit setup.
Thanks in advance
Old Feb 26, 2010 | 02:07 AM
boostedtres's Avatar
i do not know what fuel you have access to their, but if you have E-85 I would say use that. Otherwise go with the 2.2/2.3 and look into a garrett gt3076 with all the trimmings. make over to mid 400 whp and will spool like a banshee. also the FP blacks have shown some promising results but will prob be to laggy for what your looking for. 3076 with E-85 or meth on a stroker is a killer street set up for sure. gl on your build and nice call mike, ATP...ehhhh
Old Feb 26, 2010 | 03:24 AM
evillancer06's Avatar
Veteran: Navy
Fp black
Old Feb 26, 2010 | 03:28 AM
E7R's Avatar
E7R
STAY away of HKS and read this again:
Also,
Good luck...
Old Feb 26, 2010 | 09:55 AM
sktng22's Avatar
atp turbo=bad. buy yourself a 6262 and ull be fine
