Switching stock ECU maps with AEM failsafe gauge.
Old Feb 7, 2015 | 05:54 PM
okevolutionVIII's Avatar
Trying to get an idea on how this would work, using an AEM methanol failsafe gauge and haven't seen any post about being used to switch maps on the stock ECU. I have extra ECU pins to run the alternative map wire but the gauge has a + and - wire for high and low flow that triggers the failsafe method. Would both wires be connected to the alternative map pin in the ECU? I was also wanting to know if it could be used with my GM 3-port EBCS to drop it to wastegate pressure and tune the high RPM/lower load areas to pump gas AFR and timing.
Old Feb 8, 2015 | 12:27 PM
Bump
Old Feb 9, 2015 | 03:53 PM
Bump
Old Feb 14, 2015 | 12:24 PM
Bump
Old Feb 21, 2015 | 03:22 PM
Bump
Old Mar 1, 2015 | 04:57 PM
Failsafe has 2 auxiliary wires, a +12V and ground for high and low flow conditions. Would the + be installed into the ECU map switch pin and ground the other? Run both to the pin?
blacktab420
Feb 2, 2016 09:51 AM
okevolutionVIII
Apr 9, 2015 09:50 PM
superazncat009
Jun 6, 2014 11:17 PM
RealStreet
EvoX 'For Sale' Electronics / Lighting / Audio
Jul 25, 2012 09:58 AM
