Evo8 ecu in a 323 GTX
I'm looking at a cheap/reliable ecu solution for my BF 323. People scream megasquirt every time, but it's still over what I want to spend.
Give me reasons why a reflashed Evo8 ECU wont work with the right setup.
I already plan to convert to a Miata COP wasted spark with CAS setup to get rid of the distributor. I'm guessing I'll need to give the ECU a crank signal also, that I'll have to figure (I'm open to suggestions here). Can I fool the ECU into thinking there is a crank signal and only use the CAS signal?
In direct answer to the second part of your question, I'm leaning towards no only because the difference in the rates the two triggers spin and the frequency of which the sensors are triggered. They are distinctly different.
Now that being said, why not a 1g DSM ECU which never used a crank angle sensor to begin with?
hi,i cant say definitely in your case that your cas set up will be the same but having converted many evo1/2/3s and galants etc to later ecus using mitsi cas that it supplies both a crank angle signal and a tdc signal
Edit, I answered my own question in the next post... as different type sensors will emit a different signal.
From what I've learned, the earlier gen Evos use a Hall effect CAS and later model a induction type one. (correct me if I'm wrong) So if I understand this right, the cams are different and would need some type of adaptation to make all this work.
Or did I misread you and you meant that the CAS that is already there supplied those signals? If so, I'm pretty sure my distributor or even the miata CAS will have something similar, the limiting factor being that I'd have to choose my ECU in regards to that signal type.
Edit : Important piece of information here, all Mazdas I've seen use Mitsubishi electronics, genuine Mazda parts are built by Mitsubishi.
Found my own answer here :
http://www.miataturbo.net/ecus-tunin...e-74009/page2/
Post #38 : NA's use the 1g DSM CAS as well.
NA = 1G Miata that uses the same B6 engine I have.
Soooooo seems like a 1G DSM ECU swap would be pretty easy!
Aaaaand it's been done already :
http://miata.turbomirage.com/turbo_m..._upgrade2.html
Sometimes, when you know where to look....
How did you do that?
Given the choice, which ecu would you go with?
evodave
For Sale - Cars For Sale
35
Jan 20, 2006 04:52 AM
