evo 6.5 logging for etune
Old Jun 6, 2015 | 01:34 PM
DBTRA's Avatar
I know this has been a topic before, im just having an extremely hard time getting my evo 6.5 tme to log. I have an e tuner to work with me. Hes done the majority of his work with evo 8/9's. I currently have both the latest version of evoscan and ecuflash. Both will not read my ecu using the tactrix openport 2.0. I also have the reflash connector. If somebody who has successfully logged and had their tme tuned through e tuning, can you please post specific details I may be missing to successfully log and tune my ecu. Thanks a million, and sorry for the common question. Just seems like its never really covered in any threads revolving around the subject.
Old Jun 6, 2015 | 05:58 PM
nemsin's Avatar
Try lancerregister.com way more info there on early model evos.
Old Jun 7, 2015 | 04:03 AM
todd6027's Avatar
most tme are 7203fa rather than normal evo5/6 7202f so select that option when reading or pop the ecu out of the case and look at the chip.
to flash back if it is fa then you need to check your rom id xml and 5 base xml to see which memmodel either H8539F or H8539FA change the memmodel to suit and save it.
when thats sorted use f19e for mut00 / f19f for mut01 to log 2 byte load
Old Jun 7, 2015 | 04:12 AM
foxbat's Avatar
Evoscan should log the 6.5 without any issues!
Old Jun 7, 2015 | 11:19 AM
todd6027's Avatar
select mut 111 / baud rate 15625 ????
khaled_hourani
Cobb AccessPORT
Apr 26, 2017 01:41 AM
evo8vz
Oct 23, 2015 01:22 AM
waleedmango
12
Sep 12, 2014 02:02 PM
JDM EVO 6
Feb 19, 2012 12:01 PM
armysoldier1073
Dec 22, 2010 08:21 AM
