MAF Hz over 600 at Idle?
Old Dec 16, 2015 | 01:24 PM
EvilEvolution8's Avatar
Hey Guys,
I attached a log.
Like title says...at idle with stock turbo and ETS intake 3" the AirFlow 2B is too high for normal!!
What is the problem? need calibration? ETS intake sucks? Need to change MAF?
Thanks a lot
File Type: xls
Old Dec 16, 2015 | 09:38 PM
CDrinkH2O's Avatar
It sounds like you may be using the wrong MUT II reference in EvoScan, or your MUT table addresses are not set correctly. Please let us know the ROM version you are running and the MUT reference you are using for 2Byte-Airflow in Evoscan. With this info someone should be able to get you on the right track.
Old Dec 16, 2015 | 11:12 PM
96530706 tephra v7 standard MUT table.
In WOT value is around 500 and at lift off value goes up to 1300-1400.
Old Dec 17, 2015 | 01:27 AM
EvoScan RequestID = 04
EvoScan RequestID2 = 05
MUT04 = 8BB9
MUT05 = 8BDB
Old Dec 18, 2015 | 12:02 AM
Airflow seems work but airflow 2b no.
I'm going to use airflow normal
DruMMinStUd06
Jul 8, 2011 08:28 PM
Toxin
15
Mar 14, 2009 12:47 PM
Speed Element
29
Jan 18, 2006 01:26 PM
JVELA
Sep 7, 2004 07:19 PM
