Real or False Knock???
Old Dec 17, 2015 | 12:39 PM
EvilEvolution8's Avatar
Hey Guys,
Some strange knock in attached log.
Your opinion? Real or false?
Old Dec 17, 2015 | 01:59 PM
LetsGetThisDone's Avatar
That's false. Knock voltage is below 1v. Typically, around 2v is acceptable.
Old Dec 17, 2015 | 02:05 PM
So.. Every time that I found a knock sum and knock voltage under 2v it's fake and I don't care about it?
Old Dec 17, 2015 | 02:29 PM
evo8426's Avatar
Very bad assumption.
Knock voltage has never been an item I've logged or requested anyone to log. Timing and/or drastic fuel changes can cause knock, along with bumpy roads, loose nuts and bolts, things touching one another, and the list goes on.
Old Dec 17, 2015 | 02:33 PM
ok, so... there is a good way to determine that the knock fake?
I read some post in forum but I dont figure it out.
The knock series in the log happened with first gear! seems to strange the octane flag variations!!
Old Dec 17, 2015 | 02:53 PM
This is why I said "typically". Knock voltage is an excellent parameter to log. Especially in this case. Load is ~100, knock voltage is ~.7v, TPS is around 20-30%, and it doesn't have 90* of timing in it. I highly doubt that's real knock.
Old Dec 17, 2015 | 03:21 PM
evo8426's Avatar
My bad, it wasn't directed at anything you said. Just letting him know not to assume anything when attempting to learn how to tune.
Old Dec 17, 2015 | 04:30 PM
All good man. Hopefully he reads my follow up post before he adds a bunch of timing elsewhere...lol
Old Dec 17, 2015 | 09:47 PM
It's all the opposite.
I start from base map and after found a right afr... I'm going to pull down timing where knock.
Old Dec 19, 2015 | 06:32 AM
darkknightsw20's Avatar
If that load is correct and its at 3k RPM i wouldn't say thats real BUT from my new understanding of using Ecuflash and tuning these cars, Evo8426 is correct. Timing or fueling jumping from one place to another can easily dick things around.
Old Dec 19, 2015 | 06:39 AM
Load and rpm are correct... I think timing are correct for load/rpm combination...it's too strange a knock counter high like that...
Old Dec 19, 2015 | 08:00 AM
evo8426's Avatar
Not really, it is very common. Some cars are very sensitive in this area. Treat it as real knock.
Old Dec 19, 2015 | 08:02 AM
OK I'm going to fix it
Old Dec 20, 2015 | 07:36 AM
wreckleford's Avatar
Just pull some timing in that area and see if it goes away. That will tell you if it is real or not.
Old Dec 20, 2015 | 07:56 AM
Great...I will do that
jcsbanks
May 12, 2008 11:12 AM
nitz
17
Jun 21, 2007 09:33 AM
Mercenary3
Mar 19, 2007 06:05 PM
AutoXer
Nov 8, 2006 02:16 PM
Noogles
Oct 5, 2006 12:21 PM
