FE Tuning
Old Apr 18, 2016 | 10:53 PM
soeuroithurts's Avatar
FE Tuning
I'm new to the evo tuning scene(came from audi still getting use to the software) go a FE. i've been hearing the controversy about the leaner a/f. Then I heard to reflash to ecu with a gsr rom. Not sure if this can be cross flashed, I know with vws and audis, certain ecus can be cross flashed. Can 59580006(GSR) be flashed on the 52680002(FE)
Old Apr 25, 2016 | 09:58 AM
Epyon's Avatar
From what I've read and understood, the FE is just a GSR rom that was tuned by Mitsu. So there should be no problem going to the more conservative GSR rom. But you might want to just pm one of the e-tuners and I'm sure they could answer it pretty quick.
Old Apr 25, 2016 | 10:29 AM
LetsGetThisDone's Avatar
There is no issue running the stock FE rom on a stock car.
Old Apr 25, 2016 | 10:41 AM
Ok, that's what I figured. Thanks for the reply.
Old Apr 25, 2016 | 12:56 PM
If you wanted to tune it, there is more power to be had with a good tune from English Racing or similar. But if you want to leave it stock, just leave it stock. You'll be fine.
Old Apr 25, 2016 | 09:42 PM
Thanks for suggestion. Right now I'm just gonna leave it as is. But I like to self tune my cars, may not have the most numbers but its a hobby. If Im not satisfied then I will check out english, as I did see them pump out a good amount of power already out of a fe.
lancer2show
Lancer Engine Management / Tuning Forums
Mar 9, 2007 04:11 PM
