Can any one tell me how this table, "Lean Spool Correction" works?
Old Nov 10, 2016 | 12:45 AM
Raceghost's Avatar
Hi, I found this table, and am curious. I do run Lean spool at a limited level. My settings are very conservative. Start RPM 2500. Stop RPM 3750. My AFR values only increase .2 in the 11 AFR areas in increments of 2. Works really well. However, this table suggest the when Lean Spool is enabled, anything below the Start RPM is corrected by this table. This also suggest that the old standby of just setting the start/stop rpm tables together or the same, does in fact not fully disable Lean Spool. You must do it in the Periphery Bit's section. Because this table will still be at play.
Can anyone please advise?
Thanks in advance.
Old Nov 10, 2016 | 09:59 PM
Raceghost's Avatar
Bump
Old Nov 14, 2016 | 11:50 AM
merlin.oz's Avatar
I believe it is a fuel multiplying factor, that is in play above the set load threshold and below the minimum set rpm.
As to just why we have such a parameter, off hand I cannot think of a reason.
Except to say that these functions are sometimes applied to atmo Mitsubishi engines eg some Eclipse roms have these maps active and so it may be useful in that application.
It does appear to be a live parameter and not just a legacy item.
Old Nov 18, 2016 | 03:10 AM
Raceghost's Avatar
Hey, I figured it out. It's an old table just renamed. It is the old LS AFR below enable. If I remember right, it works as another on off switch. LS won't enable unless below the set AFR.
jtbell86
11
Aug 1, 2020 09:23 PM
WRC-LVR
Oct 14, 2015 04:12 PM
richardjh
Aug 26, 2011 09:40 AM
richardjh
Jun 18, 2011 10:16 AM
evonut270
Nov 7, 2009 11:24 PM
