car won't start after flash
Old Jun 7, 2017 | 03:25 PM
k0lok0yboi's Avatar
Been trying to figure out the issue for a couple days now, and i am lost. Car cranks but doesnt start as if there is little fuel being fed. The read_image file was my original tune without everything I recently installed (hella modded), and the secondtune file was what im trying to use
-demodified the car, while keeping rear o2 disabled
-replaced MBC with EBC and stock MAP sensor for an OMNI 4-bar
-checked iacv, and it works beautifully--surprisingly
-can read and write the PROM, and supplied right hex value for my immobilizer, so i was assuming i didnt brick the ecu
-supplied the scalings for the MAP sensor as close as ecuflash allowed (didnt let me put in exact values but i heard it was fine)
-check the 10A fuse under the dash and its looks fine
-timing belt seems alright
figured i'd start in the ecuflash forum since thats when things went awry. Tried to upload conservative stock fuel and timing maps with a 50-d out wgdc. Might replace the 4-bar for the stock Map sensor to flash back to the original tune, but wanted to see if anyone had any experience with this. Its my first time tuning and i tried to avoid any issues whatsoever. My guess would be those ISCV tables somehow.
File Type: bin
File Type: zip
Old Jun 7, 2017 | 03:34 PM
Biggiesacks's Avatar
if you flash back to your previous rom will it start? Are you throwing any trouble codes?
Old Jun 7, 2017 | 04:00 PM
k0lok0yboi's Avatar
I was hoping not to flash back because of the new MAP sensor. I'm not entirely comfortable running my old MAP scalings with the 4-bar sensor
Old Jun 7, 2017 | 04:18 PM
its just to see if it starts, you don't have to run it after that point. You just want to verify if its tune related or something else mechanical. If you flash it back and it behaves exactly the same you know its something else. If it starts you know you need to dig into the tune. Also checking under the hood that all important sensors (Crank,Cam etc) are plugged in and well seated is a good idea.
Old Jun 9, 2017 | 11:20 AM
k0lok0yboi's Avatar
Finally flashed it back and it started but can't hold its idle. It has to be the scalings but I can't get Ecuflash to accept the exact values and it rounds it off
Old Jun 9, 2017 | 11:26 AM
todd6027's Avatar
which rom would it not start with , one in zip or second tune one ?? dis-regard
try this attached
File Type: bin
Old Jun 9, 2017 | 01:28 PM
k0lok0yboi's Avatar
try this attached
It worked!! i compared our roms and it looks like you changed a couple of bits or whatever. Thanks!
Old Jun 10, 2017 | 08:27 AM
todd6027's Avatar
Wmu240
Dec 18, 2015 10:18 AM
Wmu240
Sep 4, 2015 07:02 PM
frankd14321
Sep 10, 2010 02:00 AM
