'13 Ralliart ADC input RequestID & Evoscan boost equation
Hey everyone, I'm trying to find the RequestID for the ADC Input on a '13 Ralliart (59570004). I have my wideband hooked up as per the following thread:
https://www.evolutionm.net/forums/ev...ut-serial.html
But the RequestID doesn't work with my definition. Any help trying to locate the proper ID or if someone has it would be appreciated.
The other issue I'm having is trying to get Evoscan to show the proper Boost equation in PSI. I removed the metric lines and it currently has (map)-(baro) but the reading is completely off. I'm using the RAX fast logging patch as I'm currently using a GST map.
I'm at 2100ft elevation which is 13.5psi.
xPRimNT
157
Dec 26, 2018 08:09 AM
stokEd
51
Oct 14, 2015 06:44 PM
sstevojr
Oct 11, 2011 11:01 AM
