Changing ECUflash Default COM/USB port
Old Dec 11, 2017 | 11:51 AM
Pal215's Avatar
Hi Gents,
I apologize if this has been answered, but I searched and could not find any info on this.
I seem to be having a tough time with ECU flash when both my wideband rs232 usb cable and tactrix cable are plugged in. The software defaults to using the rs232 cable unless I unplug it, which of course causes a "fail to read from ECU" message. I checked under the "Flashing" setting in the options, but the menu is blank. Is there an .ini/setup file that could be adjusted to make ECU flash uses the proper USB port?
The version is: 1.44.4341
Thanks for your help.
Old Dec 12, 2017 | 11:57 AM
Pal215's Avatar
Any insight on this gents? i'm seconds away from installing a USB switch as a bandaid fix.
ball7068
Aug 31, 2012 07:48 AM
Tsurara
Northeast Region
Sep 3, 2007 08:36 PM
plokivos
Apr 12, 2005 09:42 PM
mvm42699
17
Aug 23, 2004 06:30 AM
