Evo 8 stutters and goes lean above 20 psi.All of a sudden.
Is this 91 or e85? If your trims are pulling fuel like you said that would make me think blend change on e85. -11 is pulling alot of fuel, where you able to verify if the ecu was hitting stoich when it was pulling that much fuel? If you change your scaling back to the way it was before compensating for the trims, clear them out by pulling the battery and then testing, does the problem persist?
So i adjusted the latency to bring trims closer to 5 percent. Problem still there.
So it still misfires or stutters but it seems to have gotten better. But i may just be lying to my self. Also injectors were cleaned and benched about a month ago.
So im doing 2nd gear pulls from around 2500 rpm WIDE OPEN THROTTLE and afrs are in check. Around the time i hear my wastegate 20 psi or so it bucks/misfires/stutters. And afrs spike up lean.
From target 11.5 or so to 12.6 then i let off. Dont wana make a crank window
I would assume a misfire would spike rich because of the unburnt fuel in the exhaust stream but i may be wrong.
I read a thread by razorlab or mrfred with similar issue. His ended up being Cam sensor but i already swapped
Yah I agree you would think a Miss fire would spike rich. If it was me I would crank the boost all the way down and try and see how the afr's respond to tuning. That is if I was pretty sure it's not a mechanical issue. You can test that the pump is getting full voltage durring cranking. It should spike full power then drop off a second or two after it starts and stabilizes. Also you should check all your vacuum lines especially the ones going from manifold to valve to fuel pressure regulator
Ill check pump voltage next.
Im almost sure dropping the boost would make it run normal. But what will that point to?
I would think it would point to needing more fuel in the higher load cell areas. If you can dial in more fuel and your afr's respond as expected then that's probably all you needed, if however they don't then that would point to a mechanical problem.From a high level though it sounds like you threw a code for running too rich so you pulled fuel, and now your running too lean, so maybe the problem wasn't you where too rich in the first place, but some other issue was throwing off the trims. That was kind of what I was getting at when I asked if you where actually hitting stoich with that -11 trim. I will add that changing injectors scaling/latency will almost for sure call for some retuning of the fuel map
I also think its mechanical but dont know were else to look. Im gonna try my brothers spollin up cop kit. See if it helps
I can also part throttle all the way to redline and no sputter and perfect afrs
Reason I said rich on idle/cruise is because you said this started with you throwing a code for trims and they where -11 which means the computer is pulling fuel because it was rich under closed loop. When you rescaled though that compensated.
