Unknown ROM on JDM Evo 8 GSR
Hello,
I have JDM Evo 8 GSR.
We were unable to read the ROM and found that it was running a Ralliart ECU.
We have been able to pull the ROM but are unsure if this is standard Ralliart ROM or something else.
Can someone please confirm if this is a standard Ralliart ROM and what the ROM ID is?
Does anyone have a definition file for the above mentioned ROM?
I tried 97250001 def, but it does not work with ECU Flash.
Thanks for reading.
Thanks for reading.
Inspection of bytes f52-f55 in your file, shows the ECU ID is 95960000. Someone kindly started on this definition file on EvoECU Wiki, and built a basic definition file. You will need to get it upgraded with more detailed and correct information because it is not accurate.
Alternatively you could try flashing 96530706.
nj1266
10
Jun 8, 2010 05:49 PM
