Unknown Rom: 2010 USDM Evo X GSR
Hi all,
I am looking for the definition file of the following unknown rom. It is an updated rom for the 2010 USDM Evo X GSR. I think the number is 55570006, per the Ecuflash wizard.
Anyone has the rom file?
http://www.sr20deracing.com/looneytuning/Evo/stock.hex
Thanks
Thanks
What tephra said.
Code:
<rom> <romid> <xmlid>55570006</xmlid> <internalidaddress>5002a</internalidaddress> <internalidhex>55570006</internalidhex> <make>Mitsubishi</make> <market>USDM</market> <model>Lancer</model> <submodel>Evolution X</submodel> <transmission>5MT</transmission> <year>2010</year> <flashmethod>mitsucan</flashmethod> <memmodel>M32186F8</memmodel> <checksummodule>mitsucan</checksummodule> </romid> <include>evo10base_2010</include> <table name="DTC P1238 Disable 0x0384 -> 0xFFFF Mass airflow sensor plausibility (Torque Monitor)" category="Misc" address="633e8" type="1D" scaling="Hex16"/> <table name="DTC P1241 Disable 0x03E8 -> 0xFFFF Torque monitor" category="Misc" address="633de" type="1D" scaling="Hex16"/> <table name="DTC P1235 Disable 0x0026 -> 0xFFFF Mass airflow sensor plausibility" category="Misc" address="549f8" type="1D" scaling="Hex16"/> <table name="DTC P1233 Disable 0x0028 -> 0xFFFF Throttle position sensor (main) plausibility" category="Misc" address="549f4" type="1D" scaling="Hex16"/> <table name="DTC P1234 Disable 0x0028 -> 0xFFFF Throttle position sensor (sub) plausibility" category="Misc" address="549f6" type="1D" scaling="Hex16"/> <table name="Enable catalytic monitoring (P0420)" category="Misc" address="503bc" type="1D" scaling="Hex8"/> <table name="IFMode 0x05 -> 0x23 #1" category="Misc" address="7f10b" type="1D" scaling="Hex8"/> <table name="IFMode 0x05 -> 0x23 #2" category="Misc" address="8ad5f" type="1D" scaling="Hex8"/> <table name="DoMode 0x4D -> 0x5D" category="Misc" address="8ad66" type="1D" scaling="Hex16"/> <table name="IAT Ignition Advance Compensation" category="Timing" address="56184" type="2D" scaling="IgnitionCompensation"> <table name="IAT" address="6134e" type="Y Axis" elements="7" scaling="Temp"/> </table> <table name="Timing Reduction vs Load/RPM" category="Timing" address="5064d" type="3D" level="2" swapxy="true" scaling="Timing"> <table name="Load" address="615a0" type="X Axis" elements="21" scaling="Load"/> <table name="RPM" address="61554" type="Y Axis" elements="16" scaling="RPM"/> </table> <table name="Lower Bound Ignition Timing" category="Timing" address="507a5" type="3D" level="2" swapxy="true" scaling="Timing"> <table name="Load" address="615a0" type="X Axis" elements="21" scaling="Load"/> <table name="RPM" address="61554" type="Y Axis" elements="16" scaling="RPM"/> </table> <table name="Upper Bound Ignition Timing" category="Timing" address="608e9" type="3D" level="2" swapxy="true" scaling="Timing"> <table name="Load" address="611a6" type="X Axis" elements="22" scaling="Load"/> <table name="RPM" address="61172" type="Y Axis" elements="23" scaling="RPM"/> </table> <table name="High Octane Timing Map" address="55957"> <table name="Load" address="611a6"/> <table name="RPM" address="61172"/> </table> <table name="Low Octane Timing Map" address="55b59"> <table name="Load" address="611a6"/> <table name="RPM" address="61172"/> </table> <table name="Ignition Warmup Retard" address="5b969"> <table name="Load" address="611a6"/> <table name="RPM" address="61172"/> </table> <table name="MIVEC Intake Normal Coolant Temp" address="5dbfd"> <table name="Load" address="617dc"/> <table name="RPM" address="6180c"/> </table> <table name="MIVEC Intake Low Coolant Temp" address="5ddfd"> <table name="Load" address="617dc"/> <table name="RPM" address="6180c"/> </table> <table name="MIVEC Intake Map Interpolation" address="5e3fa"> <table name="Coolant Temperature" address="6265c"/> </table> <table name="MIVEC Exhaust Normal Coolant Temp" address="5dffd"> <table name="Load" address="617dc"/> <table name="RPM" address="6180c"/> </table> <table name="MIVEC Exhaust Low Coolant Temp" address="5e1fd"> <table name="Load" address="617dc"/> <table name="RPM" address="6180c"/> </table> <table name="MIVEC Exhaust Map Interpolation" address="5e408"> <table name="Coolant Temperature" address="6265c"/> </table> <table name="High Octane Fuel Map" address="55027"> <table name="Load" address="6112c"/> <table name="RPM" address="61106"/> </table> <table name="Low Octane Fuel Map" address="552d7"> <table name="Load" address="6112c"/> <table name="RPM" address="61106"/> </table> <table name="Max Rich AFR Clip vs Coolant Temp" address="5a250"> <table name="Coolant Temperature" address="5d370"/> </table> <table name="Fuel Injector Scaling" address="536ce"/> <table name="Injector Battery Voltage Latency Compensation" address="556d0"> <table name="Battery Voltage" address="61082"/> </table> <table name="Cranking Enrichment IPW Adder (Main)" address="5753e"> <table name="Coolant Temperature" address="6124e"/> </table> <table name="Cranking Enrichment IPW Adder (Unused)" address="56b48"> <table name="Coolant Temperature" address="6124e"/> </table> <table name="MAF Scaling Part 1" address="575de"> <table name="Volts" address="61842"/> </table> <table name="MAF Scaling Part 2" address="57636"> <table name="Volts" address="6189a"/> </table> <table name="MAF Scaling Part 3" address="5768e"> <table name="Volts" address="618f2"/> </table> <table name="MAP Mass Air Flow Scaling #1" address="605b0"> <table name="MAP" address="62c8a"/> <table name="RPM" address="62c5c"/> </table> <table name="MAP Mass Air Flow Scaling #2" address="602ae"> <table name="MAP" address="62c8a"/> <table name="RPM" address="62c5c"/> </table> <table name="MAP Mass Air Flow Scaling #3" address="5ffac"> <table name="MAP" address="62c8a"/> <table name="RPM" address="62c5c"/> </table> <table name="Open Loop Load High Octane #1" address="5756c"> <table name="RPM" address="60f92"/> </table> <table name="Open Loop Load Low Octane #1" address="555da"> <table name="RPM" address="60f92"/> </table> <table name="Open Loop Load High Octane #2" address="57554"> <table name="RPM" address="60f92"/> </table> <table name="Open Loop Load Low Octane #2" address="555c2"> <table name="RPM" address="60f92"/> </table> <table name="Cylinder Fuel Trim #1" address="57e51"> <table name="Load" address="6112c"/> <table name="RPM" address="61c2a"/> </table> <table name="Cylinder Fuel Trim #2" address="5803b"> <table name="Load" address="6112c"/> <table name="RPM" address="61c2a"/> </table> <table name="Cylinder Fuel Trim #3" address="58225"> <table name="Load" address="6112c"/> <table name="RPM" address="61c2a"/> </table> <table name="Cylinder Fuel Trim #4" address="5840f"> <table name="Load" address="6112c"/> <table name="RPM" address="61c2a"/> </table> <table name="Evap Map #1" address="55d5b"> <table name="Load" address="611a6"/> <table name="RPM" address="61172"/> </table> <table name="Evap Map #2" address="55f5d"> <table name="Load" address="611a6"/> <table name="RPM" address="61172"/> </table> <table name="Boost Control Load Offset" address="53484"/> <table name="Boost Target Engine Load #1A (High Gear Range)" address="58ee5"> <table name="Throttle" address="6286a"/> <table name="RPM" address="627e8"/> </table> <table name="Boost Target Engine Load #1B (High Gear Range)" address="58f8f"> <table name="Throttle" address="6286a"/> <table name="RPM" address="627e8"/> </table> <table name="Boost Target Engine Load #2 (Low Gear Range)" address="57495"> <table name="Throttle" address="6286a"/> <table name="RPM" address="627e8"/> </table> <table name="Reactive Solenoid Base WGDC Map #1A (High Gear Range)" address="58d91"> <table name="Throttle" address="6286a"/> <table name="RPM" address="627e8"/> </table> <table name="Reactive Solenoid Base WGDC Map #1B (High Gear Range)" address="58e3b"> <table name="Throttle" address="6286a"/> <table name="RPM" address="627e8"/> </table> <table name="Reactive Solenoid Base WGDC Map #2 (Low Gear Range)" address="573eb"> <table name="Throttle" address="6286a"/> <table name="RPM" address="627e8"/> </table> <table name="Reactive Solenoid WGDC Correction Interval (High Gear Range)" address="5346a"/> <table name="Reactive Solenoid WGDC Correction Interval (Low Gear Range)" address="546b2"/> <table name="Reactive Solenoid Turbo Boost Error Correction" address="58d78"> <table name="Load Error" address="62812"/> </table> <table name="Reactive Solenoid Max Total Upward WGDC Correction vs TPS" address="58d6a"> <table name="TPS" address="62852"/> </table> <table name="Reactive Solenoid Max Total Downward WGDC Correction" address="5346c"/> <table name="Passive Solenoid Base WGDC Map #1A (High Gear Range)" address="5a286"> <table name="RPM" address="627e8"/> </table> <table name="Passive Solenoid Base WGDC Map #1B (High Gear Range)" address="5a29c"> <table name="RPM" address="627e8"/> </table> <table name="Passive Solenoid Base WGDC Map #2 (Low Gear Range)" address="5a2b2"> <table name="RPM" address="627e8"/> </table> <table name="Boost Control RPM Per MPH Xover (Gear Based)" address="546a2"/> <table name="Boost Limit" address="555b4"> <table name="RPM" address="617b2"/> </table> <table name="Boost Cut Delay Timer" address="53068"/> <table name="Throttle Map #1" address="50b7a"> <table name="Load" address="61628" scaling="Load"/> <table name="RPM" address="6157a"/> </table> <table name="Throttle Map #2" address="511a4"> <table name="Load" address="61628"/> <table name="RPM" address="6157a"/> </table> <table name="Throttle Map #3" address="517ce"> <table name="Load" address="61628" scaling="Load"/> <table name="RPM" address="6157a"/> </table> <table name="Throttle Map #4" address="51df8"> <table name="Load" address="61628" scaling="Load"/> <table name="RPM" address="6157a"/> </table> <table name="Throttle Map #5" address="52422"> <table name="Load" address="61628" scaling="Load"/> <table name="RPM" address="6157a"/> </table> <table name="Throttle Conditional Switch" address="5494e"/> <table name="Rev Limiter" address="5305e"> </table> <table name="Stationary Rev Limiter" address="53442"> </table> <table name="Speed Limiter" address="53062"> </table> <table name="Airflow Check #1" address="5ea29"> <table name="TPS-Related" address="626e8"/> <table name="RPM" address="626c0"/> </table> <table name="Airflow Check #2" address="5eb1f"> <table name="TPS-Related" address="626e8"/> <table name="RPM" address="626c0"/> </table> <table name="Airflow Check #3" address="5ec15"> <table name="TPS-Related" address="626e8"/> <table name="RPM" address="626c0"/> </table> <table name="Airflow Check #4" address="5ed1f"> <table name="TPS-Related" address="62730"/> <table name="RPM" address="6270a"/> </table> <table name="Airflow Check Offset" address="60be5"> <table name="TPS-Related" address="62cb6"/> <table name="Reactive Solenoid BWGDC-Related" address="62cce"/> </table> <table name="Torque Limiter #1" address="63a45"> <table name="TPS-Related" address="63fa6"/> <table name="RPM" address="63f7e"/> </table> <table name="Torque Limiter #2" address="63b3b"> <table name="TPS-Related" address="63fa6"/> <table name="RPM" address="63f7e"/> </table> <table name="Torque Limiter #3" address="63c31"> <table name="TPS-Related" address="63fa6"/> <table name="RPM" address="63f7e"/> </table> <table name="Torque Limiter #4" address="63d27"> <table name="TPS-Related" address="64066"/> <table name="RPM" address="63fc8"/> </table> <table name="Knock Sensitivity Load Threshold" address="561ec"> <table name="RPM" address="62aea"/> </table> <table name="Knock Background Noise Multiplier" address="59e68"> <table name="RPM" address="61d40"/> </table> <table name="Knock Background Noise Adder (SINGLE GAIN) #1" address="5ff6c"> <table name="RPM" address="61d40"/> </table> <table name="Knock Background Noise Adder (SINGLE GAIN) #2" address="59e40"> <table name="RPM" address="61d40"/> </table> <table name="Knock Background Noise Adder (TRIPLE GAIN) #1" address="5ff58"> <table name="RPM" address="61d40"/> </table> <table name="Knock Background Noise Adder (TRIPLE GAIN) #2" address="59e54"> <table name="RPM" address="61d40"/> </table> <table name="ECU ID" address="5002a"/> <table name="OBD-II Codes" address="95648"> <table name="r4 (hex)"/> <table name="r5 (hex)"/> </table> <table name="MUT Table" address="3f244"> </table> <table name="EGR Timing Advance" address="57359"> <table name="Load" address="61778"/> <table name="RPM" address="6175e"/> </table> <table name="Injector Base Latency" address="53000"/> <table name="Percent Low Temp Timing Trim vs Coolant Temp" address="561bc"> <table name="Engine Temp" address="61310"/> </table> <table name="Closed Loop - LT Trim Control" category="Fuel" address="5557f" type="2D" level="2" scaling="LT Trim Hz"> <table name="Conditions" type="Static Y Axis" elements="4"> <data>Low -> Mid</data> <data>Mid -> Low</data> <data>Mid -> High</data> <data>High -> Mid</data> </table> </table> <table name="Max Lean Oct Avg AFR vs Unknown" category="Fuel" address="57a86" type="2D" level="1" scaling="AFR"> <table name="Unknown" address="619e6" type="Y Axis" elements="11" scaling="uint16"/> </table> </rom>
The interesting thing is that I flashed the car with the 55570005 rom and it started up. Then I tuned it using the 55570005. When I tuned it with the 0005 rom, it started getting that jumpy idle. So I am thinking that the 0006 rom has a fix in it for the jumpy idle.
The car's production date is Feb 2010. So all cars after Feb 2010 should have this updated rom.
Yeah, it definitely uses the same tables as 55570005.
Bryan, that hex file looks really familiar. lol
You may need my evo10base_2010.xml to go with the one he posted.
I tried to paste it in here, but it is too big.
I posted it on the other forum in a thread with 55570005 in the title.
- Bryan
Like I said, you need my evo10base_2010.xml file.
You can change :
to:
<include>evo10base</include>
Not all the tables will be defined, but it will get you closer.
You can change :
to:
