Unknown ROM
Old Nov 11, 2008 | 09:43 PM
Dubridze's Avatar
Unknown ROM
Can anybody identify this ROM?
It is from JDM EVO7, but i can not to read this ROM by EcuFlash
File Type: zip
Old Nov 11, 2008 | 10:08 PM
evoredy's Avatar
its a another zip file inside of the zip/just no extension lol.
98650014 evo7
Old Nov 11, 2008 | 10:12 PM
tephra's Avatar
I have heard of 98640014 but not 5...
Old Nov 11, 2008 | 10:41 PM
evoredy's Avatar
it exists...took a closer look...theres an xml floating around somewhere...
Old Nov 12, 2008 | 12:00 AM
grayw's Avatar
Copy and edit 98640014.xml to become 98650014.xml, they are almost the same.
Old Nov 12, 2008 | 12:26 PM
cossie1's Avatar
98650014 is more common on the airtek turbo's however there does seem to be a few jdm 7's with the same rom id.
And that is not a stock rom
Old Nov 12, 2008 | 02:19 PM
burgers22's Avatar
Seems to be exactly the same as 98650015, I've attached that xml renamed to read that the ROM attached in post 1. No disassembly done to verify maps so use at own risk.
No it's not very stock is it Russ, now get out in that garage and build that lump up!
MB
File Type: zip
Old Nov 12, 2008 | 02:41 PM
cossie1's Avatar
MB
I've not seen 98650015 so can't comment on that 1, same as I haven't seen a 98640015 but there must be one as I have 98640016
As for the engine, I can't build it up, until the crank and bearings arrive
Old Nov 12, 2008 | 02:54 PM
burgers22's Avatar
He he, back in the bad old days, no one seemed to care about the VII ROM's except me and a few guys in diverse places such as Trinidad and Dubai. Fortunately Bez had a VII and JCS Banks and GTOdesign gave me a lot of help with the deffs so I got most of the known ones done pretty easily.
Now every bugger with an 5 or 6 wants a VII ECU and tephra has obliged magnificently with 90550001. Lucky you and BarryC managed to get the ball rolling on that!
Good luck with the latest and hopefully final build on that bloody engine, I told you it was an old banger!
MB
Old Nov 12, 2008 | 03:03 PM
cossie1's Avatar
MB
Yeh I guess I was quite late coming to the scene but then I guess if I hadn't been given some info, that I figured was worth a try, there would be no 4/5/6 owners running later ecu's still
As for the roms themselves, I have tried to grab every 7 rom i've come across, just to see what if any differences there are between them.
The definitions seem to be pretty easy to sort out now, even if there not 100% perfect they seem to be close enough
Old Nov 12, 2008 | 03:10 PM
merlin.oz's Avatar
Thats not an ol' banger! It in its prime.
A 1982 Starion block/crank making 210kw is an old banger, hehe.
Old Nov 12, 2008 | 04:06 PM
Dubridze's Avatar
I can not read my image. Have anybody working definition for this ROM?
My car tuned in Japan and i don't know what is inside my ROM....
Old Nov 12, 2008 | 11:12 PM
burgers22's Avatar
See post 7, I have attached an xml for you to be able to read your ROM.
MB
Old Nov 13, 2008 | 03:09 PM
Dubridze's Avatar
Thanks!
TariqEvo
Dec 9, 2021 12:36 AM
cedmes
Jul 23, 2017 07:34 PM
Tomvas1992
Jun 22, 2016 09:44 AM
paoloM
Jun 16, 2016 06:31 AM
Synergy87
Oct 30, 2015 06:56 PM
