Speed Density 96534706 - What am I doing wrong?
Old Apr 6, 2018 | 10:34 AM
Biggiesacks's Avatar
Originally Posted by Big Bald
how do i cross referenced the maf tune. To me that how i should come up with the numbers but i have't found any post that states how to do that.
So what i meant by that was lets say your on a flat road cruising at a constant speed, say 40mph and you log 80 load with the MAF tune. When you do the same drive with the SD tune you would want it to also show you 80 load. If it says your at 110 load then you would want to adjust that down. You would want this to be as consistent as possible between the two tunes and across the whole range of loads and rpm's. It probably doesn't really have to be this way, but if you have variance then your going to be reworking your fuel map to compensate for it. This is how I understand it anyway.
mines5
Feb 20, 2017 12:02 AM
antonio010
May 23, 2005 07:50 AM
Derek888
May 21, 2005 07:17 AM
