evoscan+ecuflash=fail
Old May 31, 2018 | 10:10 PM
Rerolling's Avatar
Unhappy evoscan+ecuflash=fail
windows 10 can't connect to my ecu to reflash, , evo scan shows ecu id0000 (found the so called fix) didn't work
installed windows framework, ftdi drivers,etc
not a voltage issue
installed lastest drivers, tried the device manager uninstall delete open port, install driver, plug in, open evoscan, didn't work
tried to reinstall evoscan, ecuflash, reboot computer, formatted my computer,
checked the help on evoscan site
Old Jun 1, 2018 | 04:13 AM
huzzle101's Avatar
I run a virtual machine with Windows 7 to run evoscan + ecuflash, dont know if you have that option but look up virtual box and if you have a copy of windows 7 you will be al clear.
Other than that i dont know why it isnt working in win 10 for you, which tactrix cable are you running ? 1.3 open port 2.0 have you tried that. Im new to this maybe a veteran can chime in.
BravoZero
Dec 18, 2011 02:21 PM
