I did, I selected the 9600 wideband but I do not see an option to tick a different wideband option in the list. Actually none of the items in the request column have wdb set. Should I try changing that in my "aem wideband" settings?
the odd thing with the "afr map" is that it is not identical to the actual afr map. I had my buddy record my aem wideband with his phone and the numbers are almost identical to what is in that afr map after a log. Obviously this isn't that accurate but they do seem to match up.
Didn't work. Log came back all 0s. I leaned it out a little and the "afr map" seems to follow the wideband readings quite well. I saw a 11.1 on the gauge and the afr map says 10.9. Better then the low 10s I saw yesterday. Going to go out for another run shortly after I lean it out some more
Thanks for trying! If I have time tonight, I will attempt to mess with it some more. I really want to turn the boost up but would prefer to have an accurate o2 log before I do so.
Back with more issues. I was going to install my 3 port solenoid and start tuning for boost but the tables I need dont work. It says the current map description is invalid or incomplete. Any ideas on how to fix this? I am in developer mode as well. All the light grey is what I need to work.
Come on guys, you can just say it. Hey you idiot, just scroll down further and all those new tables you added will show! Continuing on now... dont mind me. Going to see if I can blow this thing up tonight with some more boost!
