8859 SD pump gas stalling when reaching 140 degrees F
Old Oct 18, 2018 | 07:10 PM
hiboost2.0's Avatar
Hey guys,
Been trying to track down this issue for a little over a year now. I converted to speed density awhile ago, had this issue ever since. While warming up it will start up and run fine up until about 135-145 degrees F or 60 degrees C what i have noticed is it will go full lean and start to sputter and eventually die. If I feather the throttle to get it past ~66 degrees Celsius it will run fine until operating temp and warm. Scalings and latencies are fine. Just at a loss. Thanks for the help I can post logs and current settings, a video if requested.
Old Oct 26, 2018 | 08:34 AM
jmedina23's Avatar
Do you have logs and ROM?
Old Oct 28, 2018 | 09:42 AM
hiboost2.0's Avatar
sure, I'll try and get one up when I get to my computer
Old Oct 29, 2018 | 06:39 PM
hiboost2.0's Avatar
Here is a log and the current rom I am using. Thanks.
1250cc fic
DW 300lph
Speed density
GM AIT
2.3L
Crower M2 cams
gt3582r turbo
Old Oct 30, 2018 | 04:45 AM
jmedina23's Avatar
1250cc fic
DW 300lph
Speed density
GM AIT
2.3L
Crower M2 cams
gt3582r turbo
Looking at the data log, I don't see the AFR Ratio enable. Make sure you enable it so I can see this value. I did look at the ROM, did you convert the car SD? It seems to me map is pulling a lot of fuel from everywhere. Did you add the right injector latency? If you have any videos when starting the car showing the AFR that helps too.
