Unable to Read/Write using ECU-Flash
Old Jun 24, 2019 | 01:17 PM
Chrispy0530's Avatar
Unable to Read/Write using ECU-Flash (Resolved)
First wanted to start off apologizing if this was posted in the wrong place. I see there is a sticky, and read through most of it. However I didn't see my specific issue. The thread also hasn't been updated since Nov of last year. If need be, this can be merged into it. But figured I'd get more views as a stand-alone thread.
I'm getting a tune on Wednesday remotely, and it's been a mission trying to get a tune date worked out. So I feel as if I am short on time.
The issue:
Anytime I try pulling the ROM or anything on ECU-Flash, I get the following:
[12:02:18.695] using metadata XML ID read_evo9 from file C:/Chrispy Files/Evo ECU/EcuFlash/rommetadata/read templates/read_evo9.xml
[12:03:01.403] using metadata XML ID read_evo9 from file C:/Chrispy Files/Evo ECU/EcuFlash/rommetadata/read templates/read_evo9.xml
[12:03:01.418] J2534 API Version: 04.04
[12:03:01.418] J2534 DLL Version: 1.02.4798 Jun 13 2016 17:17:10
[12:03:01.418] Device Firmware Version: 1.16.4769
[12:03:01.418] Device Serial Number: TAFJj*Av
[12:03:03.269] sending init sequence 1 (F0F0)
[12:03:03.469] J2534 error [ERR_TIMEOUT].
[12:03:03.970] J2534 error [ERR_TIMEOUT].
[12:03:03.970] interface close
What I've tried:
  • Uninstalling / Reinstalling software and drivers.
  • Tried three different computers, Two Windows 10 machines, and one of them being Windows XP out of desperation
  • Ensured cable is snug into the OBD II port as well as the Mitsu Reflash Cable
What is weird is Evo-Scan works perfectly fine with no issues.
Any ideas?
Issue ending up being the Reflash Connector
Old Jun 24, 2019 | 03:36 PM
Biggiesacks's Avatar
From the log it looks like it is not receiving a response from the ECU. Make sure your battery is strong and charged, low voltage can cause connection problems. Also make sure everything is good with your flash connector.
Old Jun 24, 2019 | 04:13 PM
Thanks for the response. Flash connector is brand new. I just put a CTEK charger on the battery, but I'm thinking it's not a voltage issue.
I should also note when attempting to connect, the PC (all PC's actually) make a USB-Disconnect sound, and re-connect sound. As if I was unplugging / re-plugging the USB.
Old Jun 25, 2019 | 10:30 AM
ravasquez's Avatar
Hi, check all your obd2 connector pins that there's not problems, test conductivity with a electrical tester, the logs says that the interface was closed because a time out this happens to me in a Subaru and the problem was with the pins
Old Jun 25, 2019 | 08:29 PM
Thanks for the tip. Question though. If the OBD II connector pin was the issue, wouldn't this cause Evo-Scan to not work?
Old Jun 25, 2019 | 08:34 PM
That sounds sketchy, the PC shouldn't be reloading the drivers like that. Might be defective hardware.
Old Jun 25, 2019 | 08:39 PM
ravasquez's Avatar
You welcome, depends on which pin fails can cause both Evoscan and Ecuflash to malfunction
Old Jun 26, 2019 | 12:14 PM
Everything checks out fine. This has me completely stumped.
Any chance that a locked ECU that needs to be unlocked can be causing this?
Old Jun 26, 2019 | 01:32 PM
ravasquez's Avatar
Yes a locked ECU can be a issue too, if your obd2 connector its all fine the ECU for sure its locked, try with this unlocker:
https://www.aktivematrix.com/blog/ak...ix-useful-info
Old Jun 26, 2019 | 01:59 PM
Thanks for the reply!
I went ahead and downloaded ECU-Flash unlocker. But I only get prompt with a splash page and no other options show up. How do I exactly unlock the ECU with it?
Old Jun 26, 2019 | 06:23 PM
I also noticed when in the Device Manager, there is a "?" on the Tactrix Interface. Is this normal? Or could this in fact be a drivers issue? ( Which.. I've tried at least 3 different PC's. )
Old Jun 26, 2019 | 08:13 PM
jozy's Avatar
did you turn your key to pos. 2? lol
Old Jun 27, 2019 | 04:36 AM
Going to pretend that wasn't asked lol
(yes, key was set to ON/just before start)
Old Jun 27, 2019 | 07:49 AM
whtrice's Avatar
Veteran: Air Force
You said this is a new Tactrix Openport 2.0 device. I also see you have an Evo IX which is a non-CAN interface device.
Did you download the appropriate adapter?
The Tactrix site states a re-flash adapter is needed for Evo 9's
For Mitsubishi, you'll need the adapter for most pre CAN vehicles which include the 5-9 Evo.
Choose the adapter you need from the 'Reflash Adapters' drop down list on the right side of this page.
Old Jun 27, 2019 | 09:53 AM
ravasquez's Avatar
Find the instructions in the below link:
https://www.evolutionm.net/forums/ec...ml#post3695484
