Evo 8 JDM Ecu Into Evo 6 Help
Old Jul 24, 2019 | 08:06 PM
jfed's Avatar
Question Evo 8 JDM Ecu Into Evo 6 Help
Hey - I ended up finding a cheap JDM e8 Ecu that I'm going to put into my 6. I've been trying to match up the pins and everything seems to be ok except for the diagnostic pins from the 6. The 6 has 3 "Diagnostic" pins:
  1. 56 - Dignostics (1)
  2. 62 - Diagnostics (7)
  3. 79 - Diagnostics
The e8 ECU only has:
  1. 100 - Diagnostics
  2. 85 - OBDII
What do I plug in where? I'm confused as to what I need to do. Any info helps
Thanks
Old Jul 25, 2019 | 11:34 PM
Fox_IX's Avatar
https://www.lancerregister.com/showthread.php?t=254746
Old Jul 26, 2019 | 02:39 PM
jfed's Avatar
That's for the USDM - JDM is different.
I'm pretty sure I figured it out though
Old Jul 31, 2019 | 08:06 PM
AllanL's Avatar
did you get it already?
100 is the reflashing pin going to the OBD 1 port pin 26
85 is the diagnostic pin going to the OBD2 port pin 7
** thanks to the guys who shared these photos**
Old Aug 1, 2019 | 07:58 AM
jfed's Avatar
Thanks for the pics - that helps a lot. Once I get the ECU installed I'll put together a how-to and pinout for future reference
