92930012 knock+startup definitions
Old Sep 20, 2019 | 06:46 PM
MogHbIu's Avatar
Hi.
I have EUR Lancer IX 2.0 4g63 non turbo an I migrated to tephra 96532706, but have some troubles with knock control (tip-in knock) and cold startup.
92930012 xml don't have a lot of addresses/tables, I try to find it, but my disassembling isn't too good. I want to copy parameters from my stock rom.
I need some help to find these addresses:
KnockSum decay timer
Knock Load (knock ignored below these values)
Knock Multiplier - Low RPM
Knock Multiplier - Mid RPM
Knock Multiplier - High RPM
Knock Adder - Single Gain
Knock Adder - Triple Gain
Cranking Primer Initial Pulse
Post Cranking Transient Enrichment vs Coolant Temp #1
Post Cranking Transient Enrichment vs Coolant Temp #2
Start IPW latency mcsec
IPW comp starting
Thanks in advance.
File Type: bin
File Type: xml
File Type: xml
Old Sep 25, 2019 | 07:34 AM
MogHbIu's Avatar
Cold start problem is gone. That was bad ISC motor.
Now I need only knock tables.
HyperDisorder
Sep 16, 2021 10:54 PM
3gEclipseTurbo
Jan 17, 2011 07:46 PM
eag36
Mar 29, 2010 01:32 AM
DCsleeper
May 7, 2008 01:14 PM
