90550001 Tephramod V7 Ecu Controlled Boost
Old Sep 27, 2019 | 11:21 AM
Wally88's Avatar
Hey everyone I’m running the tephramod V7 for rom code 90550001. It’s currently set up for load based boost control but I want to switch over to ecu controlled boost. I have an omni 4 bar map sensor that I use to log boost which works great. I searched and couldn’t find anything about ecu controlled boost for rom code 90550001. If anyone is doing this please point me in the right direction.
Old Oct 8, 2019 | 11:56 AM
3VOLUTIONIST's Avatar
Mainly just commenting to follow the thread, I don't have anything useful to contribute sorry.
Mine (90550701) is still set to load based because I could never figure out how to setup the ECU to use my 0-5V MAP signal.. I fed it to the relevant pin (the exact number I have forgotten). Never went past that point.. I don't know how to setup l the MAP VE Voltage tables in the ROM, or if theyre even relevant..
Alf gear based boost control doesn't seem to work even though I calculated the rpm/mph values too.. (25psi in fifth gear is something I try to avoid).
domyz
Jul 27, 2022 11:54 AM
Jaseviirs
Feb 26, 2018 11:41 AM
MRGEVO
May 3, 2011 02:54 AM
jdmevo123
May 10, 2010 08:19 AM
