Outlander turbo, wont read ECU
Old Mar 29, 2020 | 09:31 AM
mateshi's Avatar
Hello guys!
I received my tactrix openport 2.0 cable couple of days ago, and I have issues with reading down the ecu with ecuflash
I have tried a lot of times now and im coming to nothing.
The ECUflash starts reading, and a second later is failing, the fail that comes up says got 0x1a response instead of 0x1b.
I am out of ideas now, have some of you guys done it before? Any solution?
Under you can get my log from ecuflash and read.xml file.
Thanks!
File Type: xml
read_outlander.xml (279 Bytes, 0 views)
File Type: txt
Old Mar 29, 2020 | 11:53 PM
OzAirtrek's Avatar
Originally Posted by mateshi
Hello guys!
Thanks!
I know with the Airtrek you need to modify the read cable. If you look on the car side plug you can see that only one pin in the plug is used. This pin does not match the tactrix plug and the issue is probably the same with the outlander. You can re-pin the plug or simply remove the wire and put another connector on there like a spade connector
Old Mar 30, 2020 | 07:06 AM
mateshi's Avatar
Done that, the 2.5mm jack connector from openport is connected to the green wire on white connector behind the OBD2 connector. Still no success..
Old Mar 31, 2020 | 12:25 AM
OzAirtrek's Avatar
Sorry im not too familiar with flashing an outlander. What year is it? Is it automatic? if so you may want to edit your read file ...
Old Mar 31, 2020 | 07:42 AM
mateshi's Avatar
Its a Outlander Turbo, 2005year and manual trans.
It will be nice if you or someone could give me a read file..
Old Mar 31, 2020 | 11:35 PM
OzAirtrek's Avatar
Sure - i can show you how to make you own
Find your read files here - C:\Program Files (x86)\OpenECU\EcuFlash\rommetadata\read templates\
Open notepad and put the below in:
<rom>
<romid>
<xmlid>read_Outlander_turbo</xmlid>
<make>Mitsubishi</make>
<market>JDM</market>
<model>Outlander</model>
<submodel>CU2W</submodel>
<year>2005</year>
<flashmethod>mitsukernelocp</flashmethod>
<memmodel>SH7052</memmodel>
</romid>
</rom>
Save it to the read template folder and call the file: read_Outlander_turbo.xml
Once you have done that you should be able to go to 'select vehicle type'' in Ecuflash and it will be an option.
Now you might have to change either the flash method or memory model to get it to work. You can see in the vehicle list the other options used. Memory model should be SH7052 (256k) as you are manual. Based on year you should be Mitsukernalocp.
If it doesnt work i would first try change to Mitsukernal and try read again. Also make sure your voltage is good - best to use a battery charger when reading/flashing if possible as low voltage can cause read/write errors
I have no idea what your ROM definition is.. there is a russian Airtrek / outlander forum out-klub.ru and also airtrek-turbo.ru - both have lots of info
Good luck!
Old Mar 31, 2020 | 11:51 PM
OzAirtrek's Avatar
Actually it seems like you might need to use MMC flash program with your open port 2.0 cable?
https://evoscan.com/technical-vehicl...lander-mh8202f
Old Apr 1, 2020 | 07:18 AM
mateshi's Avatar
Yes, I think now I have read every forum that was possible to get any info from.. I thinked about the MMC flash but the costs, and I can only do this vehicle with it..
I have now a mind on getting a PIASINI V4.3 master or KESS V2 V5.017, both from aliexpress, and just do bench-flashing with it.
But now I dont know if I should choose the PIASINI or KESS
Old Apr 1, 2020 | 02:36 PM
OzAirtrek's Avatar
Yeah sorry i have no experience with either of those. If you buy from Aliexpress you will be getting a çracked version and probably wont be getting the official update or support from the vendor...
Old Apr 9, 2020 | 02:10 PM
torker's Avatar
But I'm looking for a definition for him.. For reading this car i using Kess. My OpenPort 1.3 not working with this ecu..(
File Type: bin
File Type: rar
Old Apr 20, 2020 | 03:29 PM
OzAirtrek's Avatar
On Facebook there is a group called 'Oz Airtrek' (not mine btw). There is a guy on that group who has a manual turbo outlander that is tuned...
Old Apr 23, 2020 | 10:45 AM
mateshi's Avatar
Tried entering this group, got deleted first time i think.. Trying second time then
Fuchsig
Jul 14, 2015 06:34 AM
cdone
Oct 1, 2014 07:44 PM
GTijoejoe
Nov 16, 2008 05:01 PM
kaonashi
Jan 13, 2008 05:58 PM
roberttonge
Oct 6, 2007 12:36 AM
