Evoscan Logging problem
Old Aug 6, 2020 | 07:58 PM
Paully's Avatar
Hi guys,
My tuner and I are having an issue with the latest version of evoscan. The logs have spaces between the data which makes it very difficult to read. Has anyone else had this issue?
The tuner has not seen it before, it seems to be that only the latest version has the issue. I have contacted support at Evoscan but have had no reply. The only way around this was by using my tuners older version of evoscan to log.
Any help is appreciated?
Thanks
Cheers
Paul
Old Oct 2, 2020 | 01:50 PM
XSivPSI's Avatar
Originally Posted by Paully
Hi guys,
Thanks
Cheers
Paul
This probably isn't it but its an easy check. Check that the baud rate in evoscan matches whats in the rom. I had a similar issue long ago when a friend who did my first tune before I knew anything set the baud rate to 29411 and I only remembered it being around 30k so I tried 32500 and it connected and logged but the data was wonky. Took me a minute to figure out but correcting that fixed it.
EDIT: or are you just taking about extra blank/unlogged columns that spaces the data out causing you to have to delete columns/resize or scroll left and right in the log?
Old Oct 24, 2020 | 04:16 AM
Paully's Avatar
Thanks mate ended up being a simple excel issue my tuner had, sorry haven’t had time to reply and update thanks anyway
Taspaul
Apr 22, 2012 06:40 AM
Steveevo9
Jun 1, 2009 11:03 PM
evo7girl
May 30, 2009 07:26 AM
