XML 52370023 XML Def
Old Sep 16, 2020 | 06:43 PM
3wagon's Avatar
Does anyone have a more complete xml for this ecu? 08 SST Evo X
Missing maf scaling and quite a lot more
Cheers in advance
Brent
Old Sep 16, 2020 | 06:59 PM
Biggiesacks's Avatar
check here: http://norcalmotorsports.org/users/b.../ROMs/XML/Evo/
If your looking for more than what's there I can recommend a developer who can sell you a Complete XML.
Old Sep 17, 2020 | 06:06 AM
crimson red's Avatar
Cheers in advance
Brent
Here you go. MAF Scaling for 52370023. Add these codes to your 52370023 xml definition file.
Some tables might be able to be added if you need, but I recommend you flash 52370024 instead of 52370023. More tables are already defined for 52370024 and it is newer version for '08 SST.
Bryan shares the stock 52370024 rom here.
<scaling name="GramsPerSecond" units="units" toexpr="x/100" frexpr="x*100" format="%.2f" min="0" max="655.35" inc="0.1" storagetype="uint16" endian="big"/>
<scaling name="VoltsADC1023" units="Volts" toexpr="x*5/1023" frexpr="x*1023/5" format="%.2f" min="0" max="5" inc="0.05" storagetype="uint16" endian="big"/>
<table name="MAF Scaling Horizontal" category="Fuel" address="5753a" type="2D" scaling="GramsPerSecond">
<table name="Volts" address="610ac" type="X Axis" elements="130" scaling="VoltsADC1023"/>
</table>
<table name="MAF Scaling Part 1" category="Fuel" address="5753a" type="2D" level="2" scaling="uint16">
<table name="Volts" address="610ac" type="Y Axis" elements="44" scaling="VoltsADC1023"/>
</table>
<table name="MAF Scaling Part 2" category="Fuel" address="57592" type="2D" level="2" scaling="uint16">
<table name="Volts" address="61104" type="Y Axis" elements="44" scaling="VoltsADC1023"/>
</table>
<table name="MAF Scaling Part 3" category="Fuel" address="575ea" type="2D" level="2" scaling="uint16">
<table name="Volts" address="6115c" type="Y Axis" elements="42" scaling="VoltsADC1023"/>
</table>
kaya
Sep 21, 2014 06:42 AM
boosted91t
Jan 14, 2013 04:25 PM
McLaren F1 2003
Sep 23, 2009 09:33 PM
tom04841
Apr 10, 2009 10:24 AM
