Lean/rough idle until closed loop
Old May 10, 2024 | 12:44 PM
black_out's Avatar
Originally Posted by sunnysideup
What is different when closed loop control kicks in? Does fueling, ignition timing or does only the iacv duty cycle change. Run some logs and see what parameters change after closed loop kicks in.
I posted the log in the original post. It’s dead lean until closed loop kicks in. The IAC is at 100% the entire warm up and as soon as it goes into closed loop the trims start working along with the IAC starting to actually work. all the info is in the original post.
Old May 10, 2024 | 02:38 PM
sunnysideup's Avatar
5 Year Member
Just took a peek at the log. My guess is that a tune will likely sort it out.
Tuner will adjust the warm up and afterstart tables to correct the lean afr and play with the isc position plus ign correction to get the target rpm.
Warhawker
10
Apr 26, 2020 11:06 AM
Welcome2GoodBur
Sep 20, 2018 04:45 PM
jhoganusaf
Jan 24, 2014 06:03 PM
07EvoIX
11
Jun 6, 2012 03:29 PM
joosdawg
Jun 26, 2007 06:37 AM
