It's alive! (Speed density, stock ECU)
http://www.youtube.com/watch?v=VIBVflLvLr8
Where's meh MAF sensOr?!?! http://i37.photobucket.com/albums/e7...d/DSC01918.jpg As soon as the paint/body is done, I'll be doing the clutch break in and then el dyno. Results to come! |
info....
Details!!!!
No maf translator??
Give us more details... |
+1000 on details!!!
What details do you want? Basically, I am using a JDM MAP sensor and GM AIT sensor to measure air flow instead of the stock MAF. My ROM is patched to do all the calculations and to disable any CEL associated with removing the MAF sensor. The only physical modifications required to do this is to wire the GM AIT sensor into the ECU in place of the stock sensor signal lead. Then use a 1kOhm resistor in place of the baro sensor. Finally, swap in a JDM MAP sensor. I'm trying to get someone to look at my ROM and see about porting the patch over to other ROM ID's.
nice
This is awesome, great work to you and bez! I hope this is something we can get a write up on how to convert.
Is the temp sensor before or after the meth, I can't tell?
Originally Posted by MR Turco
(Post 6087853)
you ever plan on making this mod availiable to the evo 8 ecu roms?
depending how sucessful it is, and if Bez doesn't mind - I might integrate into the next release...
Originally Posted by tephra
(Post 6088327)
did u just wake up? :P hehe
mixmastermatt, can you post up your ROM and info, plus the base ROM that was used to do the modification? I know you are 88590015, but I wanted to do a compare.
I know you did this before but there are probably further changes in your latest? |
| All times are GMT -7. The time now is 08:30 PM. |
