It's alive! (Speed density, stock ECU)
Old Sep 6, 2008 | 03:58 PM
Tuner@Swift's Avatar
http://www.youtube.com/watch?v=VIBVflLvLr8
Where's meh MAF sensOr?!?!
As soon as the paint/body is done, I'll be doing the clutch break in and then el dyno. Results to come!
Old Sep 6, 2008 | 04:04 PM
kmcconn9's Avatar
info....
alloutDSM's Avatar
Details!!!!
Old Sep 6, 2008 | 04:42 PM
kkarim's Avatar
No maf translator??
Give us more details...
Old Sep 6, 2008 | 04:45 PM
kouzman's Avatar
+1000 on details!!!
Old Sep 6, 2008 | 05:02 PM
What details do you want? Basically, I am using a JDM MAP sensor and GM AIT sensor to measure air flow instead of the stock MAF. My ROM is patched to do all the calculations and to disable any CEL associated with removing the MAF sensor. The only physical modifications required to do this is to wire the GM AIT sensor into the ECU in place of the stock sensor signal lead. Then use a 1kOhm resistor in place of the baro sensor. Finally, swap in a JDM MAP sensor. I'm trying to get someone to look at my ROM and see about porting the patch over to other ROM ID's.
Old Sep 6, 2008 | 05:06 PM
alloutDSM's Avatar
nice
Old Sep 6, 2008 | 05:11 PM
MR Turco's Avatar
This is awesome, great work to you and bez! I hope this is something we can get a write up on how to convert.
Old Sep 6, 2008 | 05:12 PM
steadly2004's Avatar
Is the temp sensor before or after the meth, I can't tell?
Old Sep 6, 2008 | 05:14 PM
Yeah, Bez did an awesome job with the patch. Unfortunately. he is out in a jungle somewhere, miles away from civilization. I don't know when I will hear back from him with a new improved version with source code for me to test.
Old Sep 6, 2008 | 08:31 PM
RoadSpike's Avatar
you ever plan on making this mod availiable to the evo 8 ecu roms?
Old Sep 6, 2008 | 08:56 PM
tephra's Avatar
depending how sucessful it is, and if Bez doesn't mind - I might integrate into the next release...
Old Sep 6, 2008 | 09:32 PM
dudical26's Avatar
That might be the best news I heard all day
Old Sep 6, 2008 | 09:43 PM
tephra's Avatar
did u just wake up? :P hehe
Old Sep 7, 2008 | 02:02 AM
jcsbanks's Avatar
mixmastermatt, can you post up your ROM and info, plus the base ROM that was used to do the modification? I know you are 88590015, but I wanted to do a compare.
I know you did this before but there are probably further changes in your latest?
