It's alive! (Speed density, stock ECU)
Old Sep 16, 2008 | 12:47 AM
  #46
Toxin's Avatar
Sick. I'll take 2 please!
Old Sep 16, 2008 | 06:32 AM
  #47
Jack_of_Trades's Avatar
I'm gonna get an AEM IAT sensor and install it now anyways. I can log it with my Zeitronix widebands "User1" input to see how my FMIC is doing at least. Then I'll be ready once this thing hits the streets
Old Sep 16, 2008 | 06:46 AM
  #48
MR Turco's Avatar
I am doing the exact same thing. The intake manifold is coming off this winter so i can give it a light port and tap the bung on the manifold for the GM IAT.
Old Sep 16, 2008 | 10:23 AM
  #49
Tuner@Swift's Avatar
Disaster!
Not really, but I had to pull my head off yet again. I went to change the oil after 2 hrs of engine run time, and a nice mix of oil and coolant came pouring out. I did a compression check and everything came out OK. I pulled the head today and discovered a washer between the gasket and the block right at a coolant passage. Doh!
I'm having everything checked to make sure the deck and head are flat, then I'll reassemble once again. After that, I should be on the dyno and commencing my testing in depth.
Old Sep 16, 2008 | 10:32 AM
  #50
tkklemann's Avatar
Originally Posted by mixmastermatt
Disaster!
Did you make sure and check to see if the washer left an indentation in the bottom of the head? Damn, that sucks..
Old Sep 16, 2008 | 10:45 AM
  #51
justboosted02's Avatar
Disaster!
set it on fire, its the only way................
Old Sep 16, 2008 | 10:52 AM
  #52
bnice01's Avatar
What are some IAT sensors we should look into getting? I heard the AEM IAT Sensor is good because of the plastic tip resists heat soaking the sensor more.
Found it for $52 shipped HERE.
Nice find, I cant wait for this
Old Sep 16, 2008 | 10:55 AM
  #53
MR Turco's Avatar
I believe buschur stated the AEM and GM are pretty much the same sensor if not the same sensor.
I got mine from RS Autosports here for $25 shipped. It also has a plastic tip and comes with the mail connector, just need to crip the ends and feed the wires through.
Old Sep 16, 2008 | 11:06 AM
  #54
bnice01's Avatar
yeah they do look the same, good point
i like your price better
Old Sep 16, 2008 | 11:38 AM
  #55
Good looking out man! Looks I'll be needing a bung welded to my piping a lot sooner than I thought
Old Sep 16, 2008 | 01:34 PM
  #56
sabastian458's Avatar
So is this available for other roms? I would LOVE to have this. I have the JDM map, and the AEM sensor with harness, What else is needed?
Old Sep 16, 2008 | 03:54 PM
  #57
Its technically not available at all yet. Its still in its infant stages but once the ECUflash public embraces this....it'll be done in no time,lol.
Old Sep 16, 2008 | 04:35 PM
  #58
oldevodude's Avatar
Originally Posted by l2r99gst
They are probably converting to hot wire maf systems, though, not Karmen maf systems.
post 38 answered this .....
Old Sep 16, 2008 | 04:52 PM
  #59
jmtx86's Avatar
Lets get a trial file out so the rest of us can start playing
Old Sep 16, 2008 | 05:07 PM
  #60
Dapper Dan's Avatar
Well get on the ball man, lol......
