New 3D VE Maps SD Rom
1 Attachment(s)
Thought I'd make a new thread instead of cluttering up John's
This isn't really for discussion if this rom works its simply done and the rest is porting it over to new ones. I can't test this myself as my evo is gone :P Should be a straight forward test will work or wont 9417 Variant: http://www.megaupload.com/?d=OHSFQUIN 9563 Variant: http://www.megaupload.com/?d=4CAOEDQ8 I'll patch in the others once i get some confirmation the rom actually runs a car. Its a lot more tedious to patch now that I'm completely rewriting the SD sub from scratch to handle these new load points. New Table JPG: https://www.evolutionm.net/forums/at...1&d=1298095294 |
So this is a 9417 v7 rom? Might be time to switch back from 9653.
Originally Posted by GotWheelHop
(Post 9032682)
I wasn't under the impression there was a v7 sd rom for 9417.
(Post 9032710)
I thought that the SD 9417 was taken out of that thread. Might have to go revisit it.
Apparently i am an idiot. Gonna have a look at this tomorrow maybe.
Originally Posted by RoadSpike
(Post 9032641)
This isn't really a discussion if this rom works its simply done and the rest is porting it over to new ones. I can't test this myself as my evo is gone :P Should be a straight forward test will work or wont ROM: http://www.megaupload.com/?d=KH4LWMG6 XML: https://www.evolutionm.net/forums/at...y-94171715.zip Very cool. Any tips on how to expand the values in our 2, 2D tables into the 3D table? I think I remember some discussion in the SD 2.0 thread, I'll take a look there too and see if I can get this working. Many thanks to you and all who continue to work on this stuff! :beer: |
Any chance of this being a stand alone patch for the 9653xxx6 or will it only be coded into the V7 ROM?
WOW...great work. Looks like my help on the 9417 XML has gone to good use. I can't wait to get back from my deployment so I can play with SD.
It appears that many of the SD tables are not fully defined with all of the addresses and scalings ? ?
Great work on the 3D VE table though....WOW |
lets get some screen shots of what it looks like.
I can test 9653 for you.. I have it SD ready and have run the 9653 SD though have reverted to MAF untill the jitters are sorted fully. Good work.
the xml link is invalid.
Just DL it and check it out. Looking good. Looks like a real VE table now. Great job.
