ECU FLASH Tuning Questions
#61
Originally Posted by Noogles
Why are you worried what the steps are at 34 celcius. Your motor isn't even at operating temp.
My settings won't work for u do to my cams (lack of vacume= higher ISCV)
Take some time and make small 1-2 step adjustments until it doesn't hang but doesn't drop down to below 700 rpm.
#62
Originally Posted by MalibuJack
Most interesting is the "Lean spool enable" which allows you to improve your turbo's spool..
#63
Originally Posted by taenaive
You are not the only one having cams. I have all the possible mods also. I am actually interested in all of your values. do you mind posting it? so I can compare with my findings?
Edit actually mine is same as the stock rom.
Same with all the ISCV settings. I would like to learn more about this because I have the same issues. Car has stalled on me a couple times :\ I have HKS 264 cams.
#66
I've seen the lean spool enable value in all the maps, only I can't remember what I was referring to since it may be quoted out of a bigger paragraph..
okevolutionVIII
Jan 1, 2014 10:15 PM
YaroRS
Jul 13, 2009 11:27 PM
