ecuflash question: wastegate solenoid activation, boost desired engine load and other
Old Jul 13, 2009 | 12:18 PM
YaroRS's Avatar
Guys, can you please explain me, what does those things mean ?
wastegate solenoid activation ?
boost desired engine load ?
max wastegate duty ?
and what values should I use ?
Old Jul 13, 2009 | 12:42 PM
Asmodeus6's Avatar
Are you using the ecu to control boost?
Old Jul 13, 2009 | 01:16 PM
YaroRS's Avatar
I use apexi avc-r to control boost.
Old Jul 13, 2009 | 02:06 PM
THUB's Avatar
They mean nothing to you. they're only used when using a stock ECU boost control system.
Old Jul 13, 2009 | 11:04 PM
Appauldd's Avatar
Since you run and AVC-R you may want to change some values in the boost tables though......
Raise your "boost cut dely timer" to max 16319950
Raise your "boost control limiting vehicle speed to 510
Raise your "boost limit" to 319 across the table
Old Jul 13, 2009 | 11:27 PM
PeteyTurbo's Avatar
Or raise them just slightly above where you feel is safe for your car to be hitting if you still want a "failsafe"
PPM
Apr 2, 2015 09:35 AM
rodrig.diaz3
Jun 28, 2009 01:37 PM
monsta
Jun 15, 2009 01:14 AM
LaXGSR
Jun 8, 2009 12:50 PM
oreficeraffaele
Jan 28, 2007 01:47 AM
