EvoScan V.90 Is Ready
#33
rgr that and ditto on the functional changes. I don't plan on using the dashboard stuff either.
I can test the CEL stuff on lunch.. I could disconnect the maf sensor try to start to the car throwing some CEL's.. then try evoscan out....
#43
I'll check it later today.. I do have a CEL light I can trigger on demand, see if I can read the correct code, and clear it. It still lacks snapshot reading though..
FWIW the ECU+ folks are working on supporting the Mitsubishi MUT protocol and embedding useful data into the logs of their software too.. With the limitation on MAF readings in the stock ECU at the moment, I'm more eagerly awaiting that..
Again, I still protest the lack of open source of this program as originally promised, but until something else becomes available I'm using it with success..
#44
