open loop load?
Old Nov 30, 2007, 04:11 PM
roger smith's Avatar
Originally Posted by trboboost91
should there be any need to change the tps based loop control maps???
Based on your normal driving patterns. For the same TPS, different gears will produce different loads. So seems like you'd change TPS settings if you want to always go into open-loop at a certain TPS (it's not gear-dependent this way).
Old Dec 1, 2007, 03:12 PM
lemmonhead's Avatar
I think you should not change the load Open Loop tables at all.
change only the TPS Open Loop tables.
because like the other person mentioned, gear dependency is not a factor.
cruising your around 25-40 TPS. So just decrease this just above so that way when your race your instantly there and ready to go!
I make my open loop low load all 30 from 4250-5750 RPM
70 from 3500-4000 RPM
i make my open loop high load all 30 from 4250-5750 RPM
50 from 3500-4000 RPM
The reason why i set 30 in low/high load from 4250-5750 is to combate lift off knock, the open-closed loop fighting problem.
Old Dec 1, 2007, 03:55 PM
nothere's Avatar
this isn't right?
lemmon, is this the map you say I should adjust?
Old Dec 2, 2007, 08:06 AM
nj1266's Avatar
I am confused...You said not to change load open loop tables and change the tps tables. But then you say that you changed your open loop load tables and set them a certain way Could you please clarify?
Old Dec 2, 2007, 12:43 PM
Jorge T's Avatar
Originally Posted by nothere
this isn't right?
I belive the Y axis address is wrong on that table, change it to 6124 and see what I mean.
Old Dec 2, 2007, 02:33 PM
nothere's Avatar
how about for the high load?
Old Dec 2, 2007, 02:52 PM
Jorge T's Avatar
sorry..for all 4 open loop tables.
Old Dec 3, 2007, 07:32 AM
lemmonhead's Avatar
sorry for the confusion, I left my load dependent tables stock. I only adjusted my throttle tables.
Old Dec 3, 2007, 07:36 AM
lemmonhead's Avatar
yes that is the one just make sure to change both low and high
this isn't right?
Old Dec 3, 2007, 07:54 PM
PlanoEvo's Avatar
I am curious that if these can be verified by a log or WB? I think that your idea makes sense but am wondering since there are differing opinions on this....
Old Dec 3, 2007, 08:52 PM
nj1266's Avatar
Could you post the maps so we can have a visual? Could you tell us why you used these numbers?
Old Dec 4, 2007, 12:09 PM
lemmonhead's Avatar
Old Jan 1, 2008, 09:59 PM
PlanoEvo's Avatar
can you please elaborate why you feel that changing the tps tables are the better option for making the car stay in open loop than changing the load tables?
Old Jan 5, 2008, 02:58 PM
Inprogress's Avatar
So with this, no changes need to be made to the fuel tables? If so, which cells exactly?
Old Jan 5, 2008, 06:55 PM
lemmonhead's Avatar
well thats the joy of tuning right?
enjoy the process!!!!
Quick Reply: open loop load?
