EvoScan 2.0 - logging HP and Torque...
Old Feb 9, 2008 | 08:09 PM
05blue8's Avatar
Just trying to log them and can't figure out why they won't when they are flagged to log. Just getting 0's. I searched the forums and no answer...do any parameters have to be set differently than they come from an install?
Old Feb 9, 2008 | 08:15 PM
Jack_of_Trades's Avatar
I believe only speed and rpm are required.
Old Feb 9, 2008 | 08:24 PM
ohhgyeahfasho's Avatar
i think you need 2byte airflow, and 2byte load to view those parameters..im not so sure because it doesnt work on my EvoScan as well..
Old Feb 9, 2008 | 08:29 PM
nope, mine worked even before I ever did those mods.
Old Feb 9, 2008 | 09:03 PM
G20's Avatar
G20
did you, by any chance, re-ordered the sequence of the log items in the XML definition file?
It's using some other log items to do the calculation so those items need to be log first. It's logging those items but if any number multiply 0 is 0.
Old Feb 9, 2008 | 09:33 PM
DrivinMissDaisy's Avatar
What rom do you have? Mine logs HP and Torque. I had to set it up for 2byte air and load. I have 88590015. I can get you what you need.
Old Feb 9, 2008 | 09:37 PM
Wicked E's Avatar
I have that same rom and mine doesn't work Drivin...
What do you have that makes it work?
Old Feb 10, 2008 | 01:10 AM
2 byte Load
https://www.evolutionm.net/forums/sh...hlight=dummies
2 byte air
https://www.evolutionm.net/forums/sh...t=byte+airflow
The thread above also has the info for hp and toque for EvoScan.
Old Feb 10, 2008 | 01:14 AM
This is what I get when I log.
Old Feb 10, 2008 | 01:15 AM
Wicked E's Avatar
What do you need for 2 byte to work? Just add the tables you posted?
Old Feb 10, 2008 | 01:42 AM
I updated my post above with all the info.
Old Feb 10, 2008 | 10:12 AM
G20's Avatar
G20
The evoscan estimated whp and torque are set as below. You see that 2-byte load is needed first in order for the rest of the evaluation to work. Just make sure 2-byte load works correctly and places before the items below. The settings file named Data.xml and reside in the EvoScan DataSettings directory. You can change it using Notepad.
<DataListItem DataLog="Y" Color="" Display="Estimated g/rev" LogReference="gRev" RequestID="00" Eval="[LoadMUT2Byte]/95" ... /><br/>
<DataListItem DataLog="Y" Color="" Display="Estimated Lbs/min" LogReference="LbsMin" RequestID="00" Eval="([gRev]*[rpm])/454" Unit="lbs" .../><br/>
<DataListItem DataLog="Y" Color="" Display="Estimated Horsepower" LogReference="WHP" RequestID="00" Eval="[LbsMin]*9.15" Unit="Whp" .../><br/>
<DataListItem DataLog="Y" Color="" Display="Estimated Torque" LogReference="Lbsft" RequestID="00" Eval="([WHP]*5252/[rpm])" Unit="lbsft" .../>
Old Feb 10, 2008 | 05:09 PM
05blue8's Avatar
Ahhh, I did change all the ordering. Thanks for the info!! I will give that a go
Old Feb 11, 2008 | 07:16 AM
TouringBubble's Avatar
Yes, first you need 2-byte load, then you also have to log g/rev and lb/min to get the HP/TQ calculations.
Old Feb 22, 2008 | 12:27 PM
cladden's Avatar
Has anyone validated the accuracy the HP equations?
