logged Evo 9 idle Airflow values
I am looking for Evoscan airflow logged values at idle for a stock 9 and what rpm you got the reading at. as an example my car at 850 RPM is reading around 25 hz and will sometimes see as high as 32hz.
My car has Injen intake so I assume it is reading differently than a stock 9.
Paper filter vs. KN vs. Aftermarket intake numbers will help me with testing for a possible different approach to tuning MAF or tuning in general.
It would be interesting to see Evo 8 numbers for general comparison
If you could reply to this thread and post your model,idle rpm along with intake and airflow reading that will be appreciated and hopefully put to some use
Thanks
Thanks
Thanks
Thanks
45-55hz @ 850-950ish RPMs
stock maf pipe mated to 35r
38-40hz @ 900-1000ish RPMs
EDIT: gsc 272 cams/stock gears
l2r99gst
Aug 28, 2011 03:39 AM
