Tephra Rom Mod - Ver 6 ??????
Old Jan 1, 2009, 03:36 PM
tephra's Avatar
hrmm I would rather not.
too many things are being CEL'd now
anyways as long as your TBEC is ok (and your using ecu boost control) then the ECU will sort out the problem...
Old Jan 2, 2009, 04:24 PM
Darwinn's Avatar
Dave, please this time mod for 88840017
Thanks
Old Jan 2, 2009, 05:11 PM
tephra's Avatar
yay that will be the first one
Old Jan 2, 2009, 09:02 PM
EvoM Community Team
fostytou's Avatar
Just throwing this out there: https://www.evolutionm.net/forums/6517434-post177.html
As always, thanks again and god-speed tephra!
Old Jan 3, 2009, 12:45 PM
Vigman's Avatar
Can you let an open option to have the CEL flashing if engine rev = rev limit on valet parking mode enable??? (for example to explain a car jacker that the car is actually screwed...)
I like all the work around WGDC...It's gonna be great!
Thanx Dave for all of us!
Happy New Year !
Old Jan 3, 2009, 05:08 PM
MR Turco's Avatar
Originally Posted by eitan
tephra: Are you planning on releasing V6 for 96420007 (or 08 or 11)?
Originally Posted by tephra
no SD for v6.
eitan - yes 11
Tephra, just wondering if you or mrfred will have support for ecu controlled boost with 96420011. Currently there is no support and i know you both have stuff on your plate. I know 08 is supported which would benefit more from this patch if you want to use that instead.
Thanks!
Old Jan 3, 2009, 05:33 PM
nothere's Avatar
Mr T.
did they run the A team down under?
should I be installing anything in particular to my roms (or whatever I should be calling them) to be ready for V 6?
Old Jan 3, 2009, 05:37 PM
MR Turco's Avatar
Originally Posted by nothere
Mr T.
Hahaha i dunno. Those are actually my initials Mike R Turco, but i originally wanted an MR when i joined the forum.
Old Jan 6, 2009, 01:58 AM
Oracle1's Avatar
Any Chance of 3 Map Switching?
Old Jan 11, 2009, 06:53 AM
THUB's Avatar
I'm obviously not the right one to answer this, but I'm pretty sure the ECU is running low on memory now with all the other stuff the tephra patches add. the ALTMAPS take up a ton of space.
Old Jan 11, 2009, 02:56 PM
tephra's Avatar
there is enough space for another set of altmaps, its just coming up with a way to activate them is hard
Old Jan 11, 2009, 06:25 PM
i2obert's Avatar
What about using a rotary switch like the one above this is a 6 position one but you could dumb it down to say 4
have one for day to day driving race fuel one with flat shifting and antilag and so on
i will keep a eye out on this thread as i have been thinking about going evo 8 ECU over my power FC as all the features you keep chucking on these is mind blowing.
Old Jan 11, 2009, 07:06 PM
Jim in Tucson's Avatar
Dave,
Is there room in the ROM for separate ECU boost control for both the reg maps and the alt maps? So we could have, say, a 91/93 tune at 21/23 psi and an E85 tune at 28 psi.
Old Jan 11, 2009, 07:11 PM
tephra's Avatar
so what 3 altmaps?
Old Jan 11, 2009, 08:32 PM
MJ23FE's Avatar
Having a switch for a map geared toward maximum fuel economy would be great!
-Jalal
Quick Reply: Tephra Rom Mod - Ver 6 ??????
