Evoscan 2.5 maptracer question
Old Jan 29, 2009, 09:35 AM
raasfaas's Avatar
Is anyone having a problem with the maptracer in evoscan 2.5? I had it working great on my first laptop, but i've since switched to a different laptop and loaded back evoscan with my serial # and all...everything else works except the maptracer. I loaded my XML and my HEX files, and it brings up the correct data (my high octane and ignition maps) but when I load my .csv log it doesnt show anything.
Anyone experienced this...
Old Jan 29, 2009, 11:27 PM
codgi's Avatar
What OS are you running on? Vista?
Old Jan 30, 2009, 09:12 AM
raasfaas's Avatar
I'm running XP Pro just like my previous laptop.
It's weird
Old Jan 30, 2009, 11:26 AM
nonschlont's Avatar
I have the same issue w/ vista. Everything works well, except the damn map tracer! But then again, I could never get that feature to work w/ any of my versions...
Old Feb 2, 2009, 08:05 PM
raasfaas's Avatar
anyone have any idea?
Old Feb 2, 2009, 09:50 PM
raasfaas's Avatar
Is there something specific that I need to be logging for the map tracer to work? I went back to my old laptop (the one where map tracer worked fine) and loaded my most recent logs (the ones from the new laptop) and same thing, nothing comes up when I check an item. So I took a log from my old laptop and tried it on my new laptop's evoscan and it worked. This leads me to believe that I'm not logging something that I should be.
Old Feb 2, 2009, 11:14 PM
oldevodude's Avatar
Wouldn't that be easy enough to check? Look and see what items are checked. It could also be when you load your .xml and map that are required for maptracer to work properly.
Old Feb 2, 2009, 11:38 PM
codgi's Avatar
+1. Just turn on both and compare whats being logged....
Old Feb 3, 2009, 09:24 PM
raasfaas's Avatar
got it...thanks guys
Old Feb 3, 2009, 09:26 PM
Wicked E's Avatar
What was it?
-E
Old Feb 3, 2009, 09:52 PM
raasfaas's Avatar
Originally Posted by Wicked E
What was it?
-E
Well to be totally honest I dont know which item(s) I didn't select that caused it not to work so I just duplicated the selection from my previous laptop and it worked. If I remember correctly I was only logging rpm, tps, 1byte load, timing, knock sum, knock volt, and wideband. Apparently it needed one or more items to be selected.
Old Feb 3, 2009, 10:03 PM
raasfaas's Avatar
Oh btw, when you rescale your load axis, is there some change that needs to be made in evoscan to reflect this. I'm now exceeding the load on my IX (300% load) so I rescaled it to 320. But when I make a log, whenever it gets to that load it freaks out.
Any suggestions?
Old Feb 3, 2009, 10:20 PM
Wicked E's Avatar
I'll bet its the loadcalc that had to be selected.
As for your load freaking out, mine was doing the exact same thing when using the 1byte load mod. I reverted back to the 2byteload for now. I haven't had a chance to ask mrfred if I can increase the chartmax for 1byteload yet.
-E
Old Feb 3, 2009, 11:31 PM
codgi's Avatar
Any suggestions?
Try what E said and see if that solves it (temporarily switch back to 2byte) . Seems like an odd number to max out the load but I haven't looked at the calc for 1 byte either so....
Old Feb 4, 2009, 04:57 AM
raasfaas's Avatar
Okay I'll try the 2byte load when I get in from work later.
But i'm sure it's some calculation that needs to be done to the 1 byte load.
Thanks guys...
