trouble reading ECU.. whats wrong?
so my tactrix cable is plugged in, and i have ecu flash up (v1.38) and i keep getting this:
[14:56:47.588] sending init sequence 1 (0001)
[14:56:48.623] got 0x05 response
[14:56:48.623] sending init sequence 2
[14:56:48.634] got 0x1B response
[14:56:48.634] sending init sequence 3
[14:56:49.018] entering bootloader
[14:56:49.034] sending kernel size (0)
[14:56:49.058] sending kernel load address (0xFFFF6000)
[14:56:49.082] uploading kernel
[14:56:49.082] error transmitting kernel
[14:56:49.084] interface close
this is my first time trying to access my ecu on my computer, and i guess it dosnt like me. what am i doing wrong?
has it been sitting for a while? If the battery is below a certain voltage it wont let you read/write to the ecu.
I have this problem all the time, I cant flash or read until I drive the car some.....my 3 year old oem battery is becoming weak
Try reading the rom with the car running, it will shut the car down and then proceed to try and pull the rom. All the finicky ones that do what you describing have been solved using that method.
