tactrix 1.3 cable
Old Feb 1, 2009 | 06:08 PM
lan_evo_mr9's Avatar
tactrix 1.3 cable
Does the 1.3 cable work with the new version of ecuflash? The way I understood it, is it is able to read but not actually flash the ecu. Is that correct? Would I have to buy a new cable in order to run the new version of ecuflash?
Old Feb 1, 2009 | 08:15 PM
03RRVIII's Avatar
mine works........
Old Feb 1, 2009 | 08:50 PM
Locked's Avatar
Originally Posted by 03RRVIII
mine works........
x2
Old Feb 1, 2009 | 10:43 PM
Fawkz's Avatar
anyone know where I can get the cable? it appears they stopped selling it... and the one they sell now is $200
Old Feb 1, 2009 | 10:53 PM
acamus's Avatar
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
Either you can try with tactrix variant here or you can build one that is for logging only here
Old Feb 2, 2009 | 12:57 PM
RuckerPark's Avatar
i have a set of Ecuflash cables for sale. $95 shipped!
its the old version but still brand new in box.
Let me know!
Thanks
Old Feb 2, 2009 | 05:23 PM
Just downloaded the new version just fine. Haven't tested it out yet though. What do you do with the Low coolant timing trim maps? Do you leave them as is with negative numbers or do you adjust them to be more like your normal timing maps? Just wondering because I do have a little cold start/running idle issue for the first couple minutes. What happened to the knock sensor filter maps? just flashed the car and I'm pretty sure it got rid of my cold start/idle issue. Not sure if it had enough time to cool off but pretty sure. Anyways- great stuff. No further answers needed.
Old Feb 3, 2009 | 06:26 AM
travman's Avatar
You can zero them out.....or you can disable the cold timing trim in the periphery.
Knock filter maps were not correct, they were replaced with the correct knock adjustment maps.
Old Feb 3, 2009 | 05:35 PM
If I have bit 9 in the FAA set to 0 then those maps have no bearing on anything? I'm running E so I have it disabled. Would adjustment of those maps give me better start/idle than just turning it off?
Old Feb 4, 2009 | 04:19 PM
GTijoejoe's Avatar
My cable does not work with 1.40. I purchase 05/09
bigben
Feb 26, 2012 06:42 PM
EatSleepBoost
May 18, 2011 05:13 PM
RoadSpike
Lancer Engine Management / Tuning Forums
Jan 29, 2011 01:08 PM
cij911
Aug 12, 2010 11:46 PM
fas-n-furyus
Jul 29, 2009 12:07 PM
