Hitting a max value for EvoScan AirFlow
I was doing some logging on EvoScan and tried to log the AirFlow. Reading starts OK but at 5500 RPMs the aiflow gets to 1593 Hz and it just stays there until redline. I am doing 22 PSI when that happens. Im I doing something wrong? Is there something that needs to be changed.
I am using EvoScan v2.1 because I have it setup for my ROM with all I need. The formula on EvoScan is 6.25*x
I did a 3rd Gear Pull tonight and got some #s for 2 Byte Airflow. Car is almost at 2000 Hz t Redline. Below is the plot.
Do the Airflow numbers look OK? I am trying to determine if the 20G is really working like it should. I have no data on the Stock Turbo.
Rall1boy
15
Aug 16, 2012 06:42 AM
