Running e85 at 12.5 AFR WOT
Old May 22, 2009 | 07:17 PM
house_of_senate's Avatar
Anyone done this? My car did for one night when it was really cold and I didnt have my wideband in...It ran FAST though. Anyone think it would cause damage over time?
Old May 22, 2009 | 07:32 PM
diiirk@AwdMotorsports's Avatar
Originally Posted by razorlab
I have. I have not seen any significant power gain from 12.0 to 12.8 on the dyno
same here, i have not seen gains that would be worth running it that lean.
Old May 22, 2009 | 08:23 PM
Deepnine's Avatar
12.5:1 as the wideband shows when calibrated for gasoline? (lambda ~0,85)
Or real afr 12,5 for e85 (lambda ~1,3)
Old May 22, 2009 | 08:39 PM
Calibrated for gasoline
Old May 22, 2009 | 08:53 PM
cfdfireman1's Avatar
ahhhhhhhhh stupid question....
...if you didn't have the "wideband in" how do you know what the AFR was?
Old May 22, 2009 | 10:49 PM
JohnBradley's Avatar
Ethanol is an oxygenate fuel, so running leaner than what is generally expected (11.5-12.0)doesnt help. Running a little richer might not actually be bad as it is on gas though. Testing to follow.
Old May 23, 2009 | 08:27 AM
jrohner's Avatar
That's about the AFR I run my car at. It doesn't seem to run that great if I go much richer than 12 or so.
Old May 23, 2009 | 08:30 AM
justa4banger's Avatar
my tuner has me tuned for 11.5-11.8 on e85 and it feels smooothhh threw the pull with no knock...but why go 12.5af, thats just too lean...
Old May 23, 2009 | 06:41 PM
C6C6CH3vo's Avatar
You mean not rich enough?
Old May 24, 2009 | 12:47 AM
fostytou's Avatar
EvoM Community Team
Same thing?
Old May 24, 2009 | 01:06 PM
My butt dyno likes 12.5 WAY better than 12.0...Ill find out soon how accurate it is.
Old May 30, 2009 | 08:04 PM
Question ""Running e85 at 12.5 AFR WOT"" I'll ask again...
...how do you know you were running at 12.5 without the "wideband in"?
Old May 30, 2009 | 08:38 PM
EVO8LTW's Avatar
This is like the weekly Click & Clack puzzler....
Old May 30, 2009 | 09:33 PM
mrfred's Avatar
I ran about 12.75-13:1 for the first part of last winter (induced by the cold weather). The main thing I noticed was that the car would often hesitate under accel because the stock ignition system wasn't able to ignite the lean mixture.
Old May 30, 2009 | 11:18 PM
GST Motorsports's Avatar
I put my personal evo on the dyno today to tune it for some added mods.
I ventured from 11.8 to 12.8 and there where no horsepower gains.
YMMV.
