TephraMod V7
#2717
hey guys, can you explain me when these tables are triggered either first or the second
and whad does that % mean on the right column
also what does "fuel cut multiplayer" table do
photo hosting
photo hosting
#2718
photo hosting
photo hosting
You use one set or the other, not both.
They are triggered when those loads are reached x for the time period milliseconds indicated in the boost limits table.
#2719
you mean in boost cut delay table ? (I have 1000 ms there)
so looking at the first table, if I hit 230 load @4000 rpm for more that one second, ecu will cut the fuel ? I understand correctly ?
#2725
Problems with 90550701-mods.bin
Just donated for a copy of 90550701-mods, all the tables are empty and I can't enter values into them.
Any help greatly appreciated.
G.
G.
#2727
The 90550001.xml is in there and I've tried a couple of different versions downloaded from around the place. I've also tried different versions of Ecuflash, just to be sure.
90550001-v5.10fix-mods also doesn't load properly, I get the rom definition but nothing else.
But then 96530706-MBforVII_base and others work perfectly, so I don't know what is going on. It's like it's not reading the xml's properly??
TephraMOD-90550701-v7 is only 12kb, which is kinda small compared to some of your other mod files?
I'll try installing it all on another computer and see if that helps, obviously others aren't having these problems so it must be a hardware/setup thing at this end.
G.
G.
#2728
open the XMl and look at what file it is inheriting. then check to confirm you have those files in the ECUFlash folder.
also, if the table shows with no data, then it is usually a scaling issue. either incorrectly defined or not at all.
cheers
cheers
#2730
We've been discussing stock ecu anti lag for a while. and what you're asking doesn't work to the effect of producing boost. Further more I have started a whole thread which thus far has reported nearly no effect according to anyone except John Bradley and Evors. I'm working on it though.,
