HOW-To 96260009 JDM8MR to 96530706
#107
I'll looking at buying an Evo8MR ecu for maybe fitting to my car in the future. The current owner has no car to plug it into and mine won't work without extensive pin changes. Can you identify which rom the ecu will be from the number on the board? It has JE331B56604B printed on it.
#109
if ur o2 sensor is faulty it might be reading the wrong voltage and hence might think its running rich or lean when it isint... so after a while the ecu gives up trying to adjust and throws p0170.
hence i would say try another o2 sensor... not sure why it would go due to the ecu... maybe it just was a coincidence
#110
it would have made my life a lot easier if the ecu threw a code when my o2 went south...damn thing caused me a right headache.
#113
but then again i can't get livemap to work either, keep getting errors.
mrfred
Feb 26, 2022 06:16 PM
