ID2000s/FIC 2150s on MAF? Anyone doing this?
Old Aug 19, 2010 | 03:37 AM
Fast_Freddie's Avatar
Veteran: Navy
Just wondering if any of you guys are running the ID2000s/FIC 2150s on the MAF? If so what are your scaling and latency settings?
The reason I ask is I installed some High Z 2000s last night and used JohnBradley's scaling and latencies (derived from an SD car) and my car would not start at all... We chatted a bit last night to get a game plan going, but we can't remember if anyone with a MAF is actually running these or not...
Old Aug 19, 2010 | 07:48 AM
tephra's Avatar
EvoX + MAF + ID2000's
Minimum IPW (currently still being tuned) = 1.136ms
Injector Scaling = 1539
Injector Latency =
4.69v 2.01
7.04v 1.38
9.38v 0.915
11.73v 0.660
14.08v 0.495
16.42v 0.405
18.70v 0.285
That's with the new latency scaling formula for EvoX (0.015 instead of 0.024)
Old Aug 19, 2010 | 07:53 AM
buchnerj's Avatar
Evo IX + MAF + ID2000's
E-85
Minimum IPW = 1.3ms
Injector Scaling = 1218
Injector Latency =
4.69v 5.232
7.03v 2.400
9.38v 1.368
11.72v 0.888
14.06v 0.600
16.41v 0.456
18.68v 0.360
Pump gas
Minimum IPW = 0.9ms
Injector Scaling = 1624
Old Aug 19, 2010 | 07:55 AM
05blue8's Avatar
Are you running e-85, 93, 91? Here are the initial settings that I used -
Scaling 1949 on pump, 1539 on e-85. Keep in mind these settings were used and the car started right up and idled great, albeit rich. It could be a good starting point to get it to fire up at least. I'm not saying that these are the ideal settings to use long term, but they should get it to fire up.
5.208
3.504
1.512
1.104
0.96
0.648
0.384
Side note - are you resetting the ECU? After trying 3-4 different latencies and scaling numbers and it not working I reset the ECU and then tried one of the ones that didn't work when I was trying different maps going back to back and it worked fine after I had reset the ECU. Coincidence? Perhaps, but it's happened twice now so I only try two latency and scaling sets before resetting the ECU. You should check out this thread for ideas also -
https://www.evolutionm.net/forums/ec...llllppppp.html
Old Aug 19, 2010 | 08:00 AM
Veteran: Navy
Thanks for that input Tephra, hopefully I actually have time to mess with the car today, and atleast get it to start and idle so i can see what is going on...
Old Aug 19, 2010 | 08:04 AM
Veteran: Navy
E-85
Minimum IPW = 1.3ms
Injector Latency =
4.69v 5.232
7.03v 2.400
9.38v 1.368
11.72v 0.888
14.06v 0.600
16.41v 0.456
18.68v 0.360
Pump gas
Minimum IPW = 0.9ms
Interesting Latency settings...
Old Aug 19, 2010 | 08:06 AM
Veteran: Navy
5.208
3.504
1.512
1.104
0.96
0.648
0.384
Yes resetting the ecu... just didn't have much time to work on the car last night as it is my daily driver...
Old Aug 20, 2010 | 12:01 PM
Veteran: Navy
Aight, using tephras settings and dropping the IPW minimum to 1.040 the car idles at 14.7ish and can actually use the fuel trims to keep up. Just got done retuning the car on pump gas at 30 psi, feels good. I will run 1 more tank of 93 through to clean the injectors some more, and it is time for E85 again!
Old Aug 20, 2010 | 12:06 PM
JohnBradley's Avatar
-8 to -13 at 1.04 is still what I consider acceptable on gas. Not sure what your trims are. E85 is better of course but still in the basic window (-5 to -10).
aaron
Old Aug 20, 2010 | 12:46 PM
Veteran: Navy
It is actually at +5-6... boy did the change my fuel map and scaling... now I am hitting 340 load! I had to rescale my maps...
Old Aug 20, 2010 | 02:45 PM
Always pulling seems to work better than always adding FYI, makes starting easier in most cases.
Old Aug 20, 2010 | 04:14 PM
Veteran: Navy
Start up is perfect on pump... if I get the trims to pull fuel, it automatically begins idling at 12.0 afr, that is why trims are on the lean side...
Old Aug 20, 2010 | 05:30 PM
You mean before the O2 starts cycling it wants to idle at 12.0? Still learning with your MAF combo since I have only done the SD and only IX's so far.
aaron
Old Aug 20, 2010 | 08:52 PM
Veteran: Navy
No, as soon as it transitions into closed loop if the trims are negative (on my setup anyway) it slowly works its way down to 11.9/12.0 afr and stays there...even bumping the injector scaling way up didn't help, due to the IPW minumum. May be different on the IXs as they have a lower IPW minimum already set up in the rom...
Old Aug 21, 2010 | 09:32 AM
Veteran: Navy
Here is a screenshot of Evoscan for the ney sayers...
Attached Thumbnails ID2000s/FIC 2150s on MAF?  Anyone doing this?-2000cc.png
