disable the immobilizer
Old Feb 2, 2011 | 12:09 PM
sk8terdude929's Avatar
Is there a way to disable the immobilizer in the XML file? im not good with the periphery bits; so i dont want to mess with them. but i have worked in the xml file before. thanks
Old Feb 2, 2011 | 12:28 PM
jonmorera's Avatar
From: Costa Rica with business addres in Miami FL 33166
Is easy buddy just check this:
http://evoecu.logic.net/wiki/Periphery_Configuration
Old Feb 2, 2011 | 02:03 PM
Thanks i will give it a try, anyone else disable it another way?
Old Feb 2, 2011 | 02:29 PM
tscompusa2's Avatar
just load your rom up and scroll down to periphery0 (FAA) Bits
and open it then set bit3 to 0 to enable the immobilizer disabling. (4th one up from the last)
by default it will be set to 1 of course. (immobilizer enabled)
Old Feb 4, 2011 | 08:35 AM
after loading the periphery Bits i have some other options to disable, i disabled my immobilizer so i have to check if that worked; but can i disable the EGR and Evap stuff from there. if so do i have to make changes to my tune?
Also thanks for all the help already.
Old Feb 4, 2011 | 02:52 PM
tscompusa2's Avatar
yes you can disable it.
Old Jun 13, 2011 | 09:16 AM
galantman03's Avatar
I have a question, I've followed that link for the directions to add the periphery bits, but it won't let me save it on the evo7base. Is says that the file directory doesn't match. Am I missing something? I have tried the FFFF or 0xffff to disable it, but the g still won't start, now I can plug the stock ecu in, and it fires up fine. I even metered the conversion harness to make sure everything was connected, and it is. This is what I do, I open this up with note pad, C:\Program Files\OpenECU\EcuFlash\rommetadata\mitsubishi\evo\ evo7base.xml
copy and pasted the tables for the periphery bits into there but it will not save it at all, I have even went through all of r3compile's videos... please help this is the only thing thats keeping me from starting and tuning the evo 8 ecu in my g Thanks in advance
Old Jun 13, 2011 | 01:10 PM
todd6027's Avatar
send me your e mail address il send you a 7 base
Old Jun 13, 2011 | 01:36 PM
Thanks man wileyman45@hotmail.com
Old Jun 14, 2011 | 05:05 PM
anybody else have any ideas on what I need to do? any help would be greatly appreciated
Old Jun 14, 2011 | 05:14 PM
BLK_EvIL's Avatar
If you disable the imobilizer can you just get a new key cut and not have to program it?
Old Jun 14, 2011 | 06:04 PM
dparrish's Avatar
I believe so. That's what the immobilizer stops. I know in Australia I need to have an aftermarket immobilizer that cuts power to everything else so that I can get insurance for it, so disabling the factory immobilizer wasn't a huge problem for me.
Old Jun 14, 2011 | 06:48 PM
BLK_EvIL's Avatar
that would be nice nearest dealer is like 3hrs
Old Jun 15, 2011 | 05:45 AM
todd6027's Avatar
Originally Posted by galantman03
Thanks man
Sent
Old Jun 15, 2011 | 10:30 AM
^thanks again! now I can see the table in ecu flash, now I just gotta figure out how to disable immob. lol
