Converted to Tephra v7, stationary rev limit/ NTLS clutch switch issue
Hey guys,
I just recently converted from a 90550001 Tephra V5 to 95630706 Tephra V7.
Before my stationary rev limit and ntls was working great. With the new map the stationary rev limit and launch maps will only work when i am NOT pressing the clutch however the NTLS will work just fine.
If i disconnect the ground source from the clutch switch the stationary rev limit and launch maps work however the NTLS thinks the clutch is always being depressed when its not.
Has anyone run into something like this?
I hope there is somewhere in the definition i can change a 1 to a 0 and fix this.
I'm a noob, all is working. Neither the NTLS nor the stationary limit were working as they should. I am using a 5 pin relay in clutch switch setup, ecu pin 43 is going to pin 30 on the relay, moved ground from 87a to 87 and all is well.
franzcars
Jul 26, 2023 09:27 AM
